Tub Surround Tiling - Materials & Layers - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-04-2019, 10:22 PM   #1
Rewards Points: 78
Hi All. I am looking to redo bathroom tile around tub area as it's currently in a poor shape, leaking and dripping water into the basement. After much of the research I came up with the following materials/layers as shown on the cross-section diagram below. Will this setup last 20 years or so? Don't want to deal with the same problem 3-5 years from now. Any advice/suggestion is much appreciated!
Tub Surround Tiling - Materials & Layers-screen-shot-2019-01-04-10.22.16-pm.png   Tub Surround Tiling - Materials & Layers-screen-shot-2019-01-04-10.28.56-pm.png
davison0976 is offline   Reply With Quote
Old 01-05-2019, 07:07 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,692
Re: Tub Surround Tiling - Materials & Layers
That is the correct way to do it with exception noted belos. I go one step further. If my tile can be positioned to within 1/8" or so from the tub surface, I don't caulk it. Basic theory is this: if moisture does get behind the tile, thinset and cbu, it hits the vapor barrier. Where does it go. With a sealed bottom it gathers at the bottom. Not that it would hurt anything, but I don't like water. By leaving the gap, you will allow the moisture to evacuate harmlessly into the tub.
But doing it the way the pictures show is completely correct with the exception of the vapor barrier's positioning. It should be BEHIND the cbu rather than in contact with the thinset.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 01-05-2019, 07:58 AM   #3
Rewards Points: 2,361
"cbu" = cement board? How do you paint the RedGard behind the cbu?
huesmann is offline   Reply With Quote
Old 01-05-2019, 08:25 AM   #4
Naildriver
chandler48's Avatar
Red Gard isn't painted on behind it. Use a vapor barrier (6 mil) behind the cbu. Use Red Gard to cover boogers and cubbies. It isn't needed for the entire shower stall. Yes, cbu= concrete backer underlayment.
Larry......
Old 01-05-2019, 12:46 PM   #5
Rewards Points: 78
Besides the unfinished look, wouldn't 1/8" gap invite water to stay there through a capillary action? I've done some testing and it seems water just loves to stay in small horizontal gaps like that without draining. That in turn, will invite the standing water to wick into the thinset mortar and the cement board.
On the other hand, if water is facing grouted lines and sealer between tub and a tile it will drain off and evaporate from the surface. Furthermore, grout cures to a higher psi (over 4500psi) compared to thinset mortar offering lower water permeability and much dryer overall wall construction.
Old 01-05-2019, 03:10 PM   #6
Naildriver
chandler48's Avatar
I've never had water "stay" in the area. There's too much space between the bottom of the tile and the bottom of the cbu for water to wick its way up there. Grout is surely less permeable than thinset, but it happens. Either way is good. I was just indicating what I did. I also don't have clients that have to repeatedly either clean the silicone in that gap or replace it once moisture DOES get back there and mold. Just giving you a Plan B.
Larry......
The Following User Says Thank You to chandler48 For This Useful Post:
davison0976 (01-06-2019)
Old 01-06-2019, 10:13 AM   #7
Rewards Points: 78
Thank you Chandler. Much appreciate the feedback!
Old 01-24-2019, 01:46 AM   #8
Rewards Points: 484
Check out the Kerdi membrane products. They will guarantee that water does not get into the subflooring and the mat also serves as a transition membrane so less chance of tile breaking or grout being disturbed. Mortar goes down and then the Kerdi membrane and then the tile is put down on the membrane with thinset.
Calson is offline   Reply With Quote
Good surround adhesive and removing old caulk sh40674 Remodeling 6 12-04-2013 08:48 PM
Tiling Bathtub Surround - Tiles of varying thicknesses neato Tiling, ceramics, marble 5 10-25-2013 07:48 PM
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 08:37 AM
Tiling a Tub Surround Paul the dyi'r Kitchen & Bath Remodeling 3 04-06-2011 05:47 PM
Tile Tub surround golfer2b Flooring 26 08-30-2008 12:25 PM
