Tub Surround - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-06-2010, 11:28 AM   #1
tub surround
can i use vinyl floor tile for tub surround
joan51 is offline   Reply With Quote
Old 11-06-2010, 12:15 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Probably not the best idea if there is also a shower. Even if there is no shower I would think the steam would have an effect on the adhesive over time. The cracks between the tiles would also be a harbor for mold and mildew.
XXX
Old 11-06-2010, 12:22 PM   #3
Rewards Points: 150
I agree with last post, you are asking for water damage, a better solution would be a simulated tile board - make sure it is the kind that is solid all the way thru and not mdf on back. These can be found in 4x8 sheets at home improvement stores. They make a vinyl tub surround corner to cover the corners and area between the tub and wall, as well.
guest is offline   Reply With Quote
Old 11-06-2010, 05:54 PM   #4
Rewards Points: 462
I've read that the vinyl floor tile adhesive depends on gravity and will fall off a wall over time.
Jim F is offline   Reply With Quote
Old 11-08-2010, 08:53 AM   #5
you may be better with wet wall panelling, no problems with steam etc then
Bobby_B is offline   Reply With Quote
Is H20 resistant sheetrock ok behind an f-glass surround? Jeffrey H Plumbing 6 11-01-2010 06:30 PM
Surround Sound Hookup Options Branden Home Theater 3 10-06-2010 02:40 PM
Tiled Shower Surround Help CluelessNewbie Kitchen & Bath Remodeling 4 02-10-2010 09:33 AM
Gap in Corner Between Tub Surround and Bathtub? Howitzer Remodeling 12 09-17-2008 04:14 PM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 10:52 PM
