Tub Size - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-24-2016, 12:15 PM   #1
Rewards Points: 164
Tub Size
Replacing a tub.
Old tub measures 4' 5".
New tubs appear to be 4 or 5 feet commonly.
Assuming I should get the 4', how does one account for the extra 5" with the walls?
giddyap is offline   Reply With Quote
Old 10-24-2016, 05:02 PM   #2
Rewards Points: 17,884
Re: Tub Size
Mobile Home?
"Standard" is 5', 4' would be a shower.
If the old tub is 4'5" why would you replace it with a 4'?
Older mobile homes used smaller tubs.
No one here can see what your seeing so would have no clue how or where you can move the wall to fit a real standard tub.
Old 10-24-2016, 05:58 PM   #3
Rewards Points: 164
Re: Tub Size
Ok, well me ask in a different way.
What does one do if a new bathtub matching the EXACT same size as the old one cannot be found?
Old 10-24-2016, 06:28 PM   #4
Rewards Points: 164
Re: Tub Size
Wait...I think I know.
If I measure the current tub at 4' 5", I want to get a 4.5' tub, and the 1" difference is the wall tile. That is, my 4' 5" is actually a 4.5' tub, except that I cannot measure the extra inch because the tile is covering .5" on each end.
Am I right?
Old 10-24-2016, 09:21 PM   #5
Rewards Points: 112
Re: Tub Size
Am I right?
That sounds correct. 4'6" tub should be available at most plumbing supplies.
paul100 is offline   Reply With Quote
New Sub Panel Wire Size? johnsas Electrical 4 08-29-2012 11:20 AM
Sink Size Specs - Advice needed donvaz Kitchen & Bath Remodeling 1 08-12-2012 01:39 PM
wire size for 1575 inverter 15' from battery bluemoonshine Electrical 8 12-28-2011 09:49 AM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 05:00 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
