Tub Install - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-14-2010, 06:18 AM   #1
tub install
I have a gap of 3 1/2" after tub sits on side ledges. Is that too much to fill with mortar.
bclaydon is offline   Reply With Quote
Old 10-14-2010, 01:07 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 12
Don't have clue what you are talking about, but somehow I still suspect the answer is "Yes, 3 1/2 inches is too big a gap for mortar".
Can you post a pic?
Old 10-14-2010, 01:28 PM   #3
Rewards Points: 258
I suspect the OP wants to support the bottom of the tub with a mortar bed. Not all manufacturers recommend this. I suggest he consult with the maker of his tub for installation instructions.
retired guy 60 is offline   Reply With Quote
Old 10-14-2010, 09:03 PM   #4
Rewards Points: 462
I wouldn't think you would want mortar bed 3 1/2" thick under a tub. Why not just lower the ledger boards. Something just doesn't sound right about this post.
Jim F is offline   Reply With Quote
Old 10-15-2010, 02:48 PM   #5
Thanks for the posts. Problem solved. I was sold a tub that was suppose to have the plumbing run underneath not through the floor. They come with a skirt that keeps the tub 3" up off the floor when levelled with the side ledges.
Bought a tub that sits on the floor like the other one. Thanks all
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 02:29 PM
Fiberock install STUPID Flooring 5 10-16-2007 06:29 PM
