Trying To Find Replacement Fan - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By TarheelTerp
  • 1 Post By mnibeck
Old 01-20-2019, 06:55 AM   #1
Rewards Points: 8
Trying to find replacement fan
Current bathroom fan needs blower bearing needs replaced, VERY loud. Current unit has fan, light AND heater. Interested in either fixing just blower portion, or replacing whole unit, donít care. Current ceiling fixture is a large circular recessed can. Unit is probabt 15+ years old. I canít find the manufacturer name on unit at all.
Two questions:
1 - Anyone know where to find parts for these?
2 - If I replace with a non-heated unit, will it fit into existing recessed can?
Mike
mnibeck is offline   Reply With Quote
Old 01-20-2019, 07:09 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,676
Re: Trying to find replacement fan
Can you post a picture of it with the light pulled down so we can see the internal workings?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 01-20-2019, 07:23 AM   #3
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,134
Originally Posted by mnibeck View Post
I can’t find the manufacturer name on unit at all.
Take some photo's. Post here and google search the rest.
Once you identify the brand or the motor type... it's a LOT easier.
Last time I did one I found that a new exh fan at HD...
cost less than just the motor from a wholesaler would.
195795 likes this.
Old 01-20-2019, 07:30 AM   #4
Rewards Points: 8
I have photos, just trying to figure out how to post them on this forum. Any help help would be appreciated....
Never mind, got it
Old 01-20-2019, 07:33 AM   #5
Rewards Points: 8
Nealtw likes this.
Old 01-20-2019, 07:34 AM   #6
retired framer
Rewards Points: 18,792
See go advanced below then manage attachments.
Old 01-20-2019, 08:28 AM   #7
retired framer
what part did you need?
Old 01-20-2019, 08:30 AM   #8
Rewards Points: 8
The fan is very noisy, so I would like to try and replace that. Bearing going out maybe??
Old 01-20-2019, 08:43 AM   #9
retired framer
I can't imagine all that fitting in the hole in the ceiling.
Might be just the motor.
Old 01-20-2019, 09:26 AM   #10
Rewards Points: 2,490
If you don't want it, I'll take it. Is it belt driven? Never saw anything like it. Try connect to power and see where the noise comes from, since you have it down. Search for motor repair shops for bearing. Should be simple enough for them. Make sure the bearing is made anywhere but china. Refer to youtube AVE for bearing qualities.
Motor could be a problem. It didn't look sealed but right temp cut off, seal/open cool, right kind of spindle , all make the replacement tricky. Motor shop may refuse to work on it, another monkey wrench for you and for them.
Some noise is from how the housing is fastened to the frame. You could try adding vibration absorbing rubbers. You could try caulking the housing seams. The fan housing, caulk or tightening the fasteners? Turn it on first and tests.
carpdad is offline   Reply With Quote
Old 01-20-2019, 12:41 PM   #11
Rewards Points: 1,272
Replace that - just like the dinosaur, it's time is over ! Remove the can, get a nice fan or light/fan and a little drywall work and you're good to go. Don't forget, if installed over shower or tub and manufacturer instructions call for it to be GFCI protected, do it !
195795 is offline   Reply With Quote
Can you help me find a replacement thermostat? Having trouble! chicy724 HVAC 68 05-14-2013 10:44 AM
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 04:46 PM
Why can't I find a good thatch rake or pine needle rake? carl1864 Landscaping & Lawn Care 5 06-05-2011 01:01 PM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 02:24 AM
Replacement shower faucet? jlajla24 Plumbing 4 11-24-2008 05:17 PM
