Trouble Removing Old Shower Pan - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-03-2015, 02:40 PM   #1
Rewards Points: 54
Trouble removing old shower pan
Either this thing weighs 200+ lbs or it's stuck, probably due to the drain being glued to the drain pipe. How do I separate the two? I can't lift it more than 6" from the floor no matter what with my own strength, but I can with levering 2x4s (shown). My fear is if I keep using levers I'm going to break something. I can't see what's going on underneath because of the plastic sheeting.
kripes is offline   Reply With Quote
Old 01-03-2015, 05:04 PM   #2
Rewards Points: 17,884
Tryed 5 times but picture would not load. (likely my computer at fault)
There is no way to remove a pan without first disconnecting from the drain.
Any access from below to cut it off.
You can cut out around it from the top with a ciruler saw with a diamond blade if it a concrete base.
Old 01-03-2015, 05:15 PM   #3
kwikfishron's Avatar
Rewards Points: 252
Bust it up....Who says it has to come out in one piece?
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
joecaption (01-03-2015)
Old 01-03-2015, 05:34 PM   #4
Now the picture came up!
That's nuts trying to remove that in one piece. And lifting it is just going to break off the pipe below the floor.
Make passes with a ciruler saw with a diamond blade to weaken it and whack away.
Old 01-03-2015, 05:48 PM   #5
Retired Moderator
Rewards Points: 7,174
Liner and concrete pan---like everyone has said---break it up---that grey liner is clamped to the drain--lift--prop so it is hollow under it--then hit with a BIG hammer.
Old 01-06-2015, 08:21 PM   #6
Green Hat
Rewards Points: 170
If you dont have access to a powerful saw, or want to keep the dust down you can drill a few holes with a masonry bit and a hammer drill and then hit those areas with your hammer. I have done that before with a concrete pad in order to knock it out.
Good luck with the demo!
Mills314 is offline   Reply With Quote
Old 01-07-2015, 07:01 AM   #7
Rewards Points: 54
Thanks everyone! Great forum
The Following User Says Thank You to kripes For This Useful Post:
oh'mike (01-07-2015)
Removing Corner Shower Tile (with pictures) JasonCA Kitchen & Bath Remodeling 16 03-30-2012 09:19 PM
Removing recently installed shower tile cm3putter Plumbing 1 12-15-2009 08:24 PM
Trouble replacing 2 handle shower levers matt7125 Kitchen & Bath Remodeling 2 12-02-2009 07:55 AM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
Trouble Removing Sliding Glass Doors Drewimus Carpentry 1 11-05-2006 12:43 AM
