Touching Up Nicks On Kitchen Cabinet Doors Before Painting - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By mark sr
  • 2 Post By F250
Old 07-11-2018, 07:16 PM   #1
Rewards Points: 30
Touching up nicks on kitchen cabinet doors before painting
We're going to be painting the kitchen cabinet doors in the condo we'll be renting out but a few of the doors have some small nicks in the laminate. What do you recommend in this situation? Will wood filler work. I looked on YouTube and there seemed to be every suggestion from wood filler, to spackle, to silicone caulk, to magical incantations.
Here's a shot. Extreme close up. Makes it look massive, but the actual nick is probably less than a cm across.
Thanks.
Touching up nicks on kitchen cabinet doors before painting-img_20180711_200058904.jpg
Woody416 is offline   Reply With Quote
Old 07-12-2018, 06:50 AM   #2
retired painter
Rewards Points: 1,426
Re: Touching up nicks on kitchen cabinet doors before painting
That's a hard place to get a lasting repair. While caulking might adhere and last longer it's not sand able and would be difficult to make look nice. I'd use Durabond [setting joint compound] but most any filler will do ok. I just wouldn't be surprised if it comes off over time.
Woody416 likes this.
mark sr is online now   Reply With Quote
Old 07-12-2018, 08:26 AM   #3
Still learning every day!
F250's Avatar
Rewards Points: 800
Get a small can of Bondo at your local hardware or automotive supplier. It's not hard to work with (just follow instructions on the can), it has a fast cure time, is easily sandable, sticks to whatever it touches, finishes hard, is easily primed/painted, and should last quite well.
To give the Bondo better "grab", you could predrill a couple of very tiny finishing brads into the clipped off corner, making sure to set them deep enough that the heads would be covered by the Bondo while still sticking out of the wood... they would provide an "anchor" for the Bondo.
I've just done something similar on a new attic door installation where I had to fill the deadbolt hole in the door and the deadbolt strike hole in the jamb. There, I was using so much Bondo that it took three applications, but the finish is perfect and more durable than wood filler or caulk.
mark sr and Woody416 like this.
Pete
Bark less, wag MORE, and Show Compassion to everyone you meet!
F250 is offline   Reply With Quote
Tags
litchen
LED Lights for glass kitchen cabinet doors enochian Electrical 2 09-08-2015 12:38 PM
vinyl kitchen cabinet doors [email protected] Carpentry 2 01-19-2012 03:12 PM
Painting multiple cabinet doors. mae-ling Painting 14 12-19-2011 09:39 AM
Kitchen cabinet doors FreddyD Painting 7 07-08-2011 02:55 PM
Kitchen cabinet refinishing. Wild Bill R Painting 0 11-25-2010 05:36 AM
