Top Mount Sink - Clip Issue - Seeking Advice - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree8Likes
Old 03-05-2019, 03:56 PM   #16
JUSTA MEMBER
Rewards Points: 3,654
Re: Top Mount Sink - Clip Issue - Seeking Advice
You could take a little rubber foot, from the hardware store, place it over the star washer, and it will grip the wood great when tightening the bolt.
If you don't want to drill the wood, or don't have room for the drill to get up there.
ED
de-nagorg is online now   Reply With Quote
Old 03-07-2019, 11:01 AM   #17
Rewards Points: 98
Thanks for the help guys. - I managed to get those suckers on there, as per Neal's genius. - This might be a bonehead question, but does anybody have a tip or tool to get a nice slim, perfect bead of sticky caulk on a lip? I always have trouble with it. I'm kind of like.. the worst caulk guy really. Is there a trick or tool out there that anybody uses particularly?
rkearns10 is offline   Reply With Quote
Old 03-07-2019, 11:33 AM   #18
retired framer
Rewards Points: 18,838
Tape what you don't want to caulk
Do not use flat bottom gables with scissor trusses.
Old 03-07-2019, 11:42 AM   #19
Rewards Points: 6,905
They smaller the hole in caulk tube tip, the smaller the bead. The tape trick works well but be sure to remove immediately.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Old 03-07-2019, 04:20 PM   #20
JUSTA MEMBER
Tape, then a WET FINGER, to wipe off the excess, and smooth out the wanted seal.
apply the bead before installing the sink, install, squeeze out some, then WET finger to smooth.
Wipe your finger on rag, wet again, remove a section.
ED
Mop sink, 3-bay sink, only one floor drain - help? summersab Plumbing 9 07-30-2017 12:39 PM
36" Kraus front apron sink in a 36" apron sink base - best way to cut/install? Quicksmoke Kitchen & Bath Remodeling 4 10-06-2015 11:18 AM
Advice on mounting a sink remhed Plumbing 10 02-24-2015 07:40 AM
Need advice on how to clean a concrete laundry sink Rav Plumbing 17 12-21-2014 08:32 AM
Mount an undercounter sink on top? nicksteel Plumbing 3 08-31-2008 07:18 PM
