Top Mount Sink - Clip Issue - Seeking Advice
4 Attachment(s)
Hi Everyone,
So I'm in the process of installing a stainless-steel top-mount sink in my kitchen on some butcher block, the thing is...I can't seem to weasel the provided clips in whatsoever. Admittedly, this sink was an off-label amazon purchase, so I'm not surprised that the clips are on the janky side. They seem not to fit in this application whatsoever. I literally can't budge them in for the life of me. - The sink in-and-of-itself is actually pretty good quality steel. It's not flimsy or warping. It mostly sits flush aside from a small problem corner that is maybe 1/16 to 1/32" of a gap.. also in the very front of the sink there is a minor gap where I created triangular front piece to bridge the miter and create a corner sink, but ultimately this gap isn't going to be sucked in, so that might not be an issue here, just some extra caulk perhaps. I plan to use a lexel clear caulk. There will be a single garbage disposal involved, which I've read the rattling could pose an issue for a caulk-only clipless sink. ---- I've attached some pics for everybody below...if you'd be so kind: 1) Is it a bonehead move to try to install the sink with caulk only? The sink is pretty sturdy as I mentioned, and it's mostly flat and flush with the surface, not really bowing or waving aside from a small portion of the right corner that needs attention. 2) I figure I could try to weigh down the small area of need where there could be some extra pressure, and I figure I could also throw something on the heavier side like a pan or bucket filled with water in the sink to provide some weight. 3) If caulk-only in this application is moronic, does anybody have any suggestions for trying to get some clips on this bad boy? Are there universal clips that might be relevant here available online or at the big box retailers? I've added pictures of the clips as well. Which will most likely be gracing my garbage with their presence. - Appreciate any help you guys! |
Re: Top Mount Sink - Clip Issue - Seeking Advice
The ones that I have seen, had clips on the underside, pulling the sink down to seal.
Using the Clear caulk ( silicon), is done often, and works great to seal any water penetration. Maybe you can adapt another type of fastener under the thing to replace what you have. Would need to see how the clips that you have are supposed to be attached, to think of any replacement. ED |
The clips might for under mounting the sink.
I bought a bargain sink that turned out one size to big for my cupboard so no room for clips, I put a healthy bead of silicone down set the sink in it with 2 5 gal pales of water in it and left it for a day. 12 years later no problem yet. |
I think Neal is right—the clips are for undermounting it to granite, et al.
Just use silicone, make sure the top flange is weighted enough so that the gap the silicone is filling is even all the way around. Make sure you have a slight bead of silicone around the edge, to minimize anything getting under the flange. |
I don't see the clips picture. Clips go under.
Is the countertop more than 3/4" thick? I seem to recall one time when I had to mortise just a bit off the bottom of the counter to get the clips to work in one spot. They often go in different than they look. A picture of the clips and the track they insert into could yield better answers. I'm old fashioned and use warmed plumber's putty but some do use caulk. A helper to push down on the sink while attaching the clips is always helpful. edit: somewhere on the box or instructions it might refer to 'top mount sink' to define it as not suitable for mounting under granite. I suggest you post a link to the product you bought for better answers. |
They possibly could be undermount clips, but they likely are top mount as they are coming with an obvious top mount flange.
Sometimes, I've had to cut or fill the bottom side of the counter to make a proprietary clip work....seems each manufacturer uses a slightly different system. However, I think you will be fine with a good bead of silicon or a high adhesive caulk like Polyseamseal. Whether that will anchor down you lippage tight is a little iffy... but the clips probably won't anyway...is the sink bent or is your counter not flat..???? I can't tell how important that lippage might be in your application and use. Good luck |
1 Attachment(s)
These are the clips..I've purchased other clips but either I'm slow or something.but I can't for the life of me see how these would even work with a top mount sink.
Now show us the underside of sink rim.
4 Attachment(s)
Here's what I'm working with underneath, not much lip room to play with on the sides whatsoever, there's also no clip type rail on the side of the sink for clips to attach to. - I'm thinking I need to just Lexel the heck out of the top lip and throw some weights on the lip itself and a few 5 gallons with water in the center.
Bend or swing the longer piece out of the way and the hooked part goes in the tab on the sink
https://www.diychatroom.com/attachme...vice-clips.jpg |
Neal has nailed it but you would expect that from a framer.
I've never bought a new sink that did not include the correct clip as a part of the package. |
I think that approach might work perhaps with a different setup, maybe a different bolt in there or some kind of shim or something to catch.I took the provided bolt/oval piece out and tried a regular decking screw with a washer but the clip doesn't get good enough right angle positioning and just falls out when I screw it in. This is driving me crazy!! But I'm going to keep thinking on it. Thanks for the help guys |
SO yeah... it seems the issue is that the clip on the sink is set farther back from the point where washer with teeth makes contact to the butcher block, skewing the angle and making it tough to get good contact. So are you saying make something like a recessed forstner hole around the circumference of the washer-with-teeth so as to lodge it into the wood depth wise? |
Just a thought but the holes would work. |
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by
Advanced User Tagging (Pro) -
vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by
vBSecurity v2.2.2 (Pro) -
