Top Coat On Laminate Counters - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-05-2015, 12:49 PM   #1
Rewards Points: 2
Top coat on laminate counters
I am wanting to redo my laminate counter tops in the kitchen. I am wondering what to use as the top coat to seal the paint that I am doing. I want something that is durable, heat resistant and can be used. I cook a lot so I want to be able to put things on it and not worry about scratching the surface or it coming off. I know that there are kits out there that have the top coat in it, but I'm not impressed with the kits and it isn't the exact look I am going for. I have tried to figure out what top coat they use, but with little luck. I have researched it and some websites say to use a polycrylic, an epoxy or polyurethane top coat. I don't know which one will work the best. Any suggestions would be very helpful!
krisfenner is offline   Reply With Quote
Old 01-05-2015, 12:56 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Not a good idea and anything you use won't last.
Laminate counter tops are made of plastic, "they" don't use a top coat of anything.
XXX
Old 01-05-2015, 01:25 PM   #3
Rewards Points: 144
This Bud guy is pretty sharp.Listen to him.
mako1 is offline   Reply With Quote
Old 01-05-2015, 01:28 PM   #4
ZZZZZ's Avatar
Rewards Points: 2,130
I haven't used it, but this Rustoleum stuff is right up your alley.
http://www.homedepot.com/p/Rust-Oleu...6068/202820906
ZZZZZ is online now   Reply With Quote
Second topcoat blisters over clean skim coat norepeat Painting 8 09-07-2011 06:30 PM
Best quality underpad to use for laminate?? sillysimms Flooring 4 07-27-2011 05:05 PM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 07:38 PM
help! installing preformed laminate counters guest General DIY Discussions 5 02-19-2011 01:07 PM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
