Too Much Flex In Cement Board For Tiling? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-08-2014, 08:47 PM   #1
Quackerjack's Avatar
Too much flex in cement board for tiling?
I'm re-doing what was once a very makeshift shower stall. I've put up the cement board and I'm nearly ready to tile with 12 x 12 ceramic tiles. But I noticed there's more flex in the cement board than I expected. Two studs are spaced 20 inches apart. Where the spacing is 16 inches, it still seems pretty flexy. In hindsight, I could have put in blocking but I didn't think of it at the time. Time and expense is a major issue but of course I don't want my tiles falling off if someone leans on the wall. I never did this before so I don't know how much flex is too much and whether the thinset and tiles will compensate.
Any suggestions? Any insight would be appreciated.
Quackerjack is offline   Reply With Quote
Old 07-08-2014, 08:56 PM   #2
Rewards Points: 1,002
What type of tilebacker, and how thick?
cleveman is offline   Reply With Quote
Old 07-08-2014, 08:58 PM   #3
Rewards Points: 17,880
Need 1/2 backer on walls and it should have been 16" O/C.
Old 07-09-2014, 11:04 PM   #4
Perma Base Brand Cement Board (from Lowes), 1/2" thick.
Old 07-10-2014, 07:44 AM   #5
If you screwed it on, does your driver have a reverse?
The Following User Says Thank You to cleveman For This Useful Post:
mnp13 (07-10-2014)
Old 07-10-2014, 08:30 AM   #6
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
Take it off and fix the studs. Any flex will ruin your work. I'm assuming that you have already waterproofed though?
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Tags
cement board , shower stall , stud spacing , tiles , tiling
Plunge cut cement board - or not? miamicuse General DIY Discussions 5 11-13-2013 08:58 PM
Type nails? - wooden trim into cement board Easypick Carpentry 5 07-21-2013 03:16 PM
question about hanging cement board in shower pillowshack Drywall & Plaster 0 01-12-2013 06:55 PM
cement board flex (a bit) rtoni Building & Construction 2 12-16-2010 02:01 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
