Toilet Rough-in - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-01-2016, 10:18 PM   #1
siggy312's Avatar
Rewards Points: 64
toilet rough-in
the toilet rough-in (3" ID ABS) was cut (not by me) flush with the basement cement floor. Once I add thinset, heating wire and tile, a standard closet flange will be way too short. It does not make sense to install a standard closet flange onto the cement then add a bunch of "SET-RITE" pieces on top. A closet flange with a LONG sleeve would work (If I could only find one). I could chisel out the cement around the ABS pipe so that I could add a union to build length. Looking for ideas/options.
siggy312 is offline   Reply With Quote
Old 05-01-2016, 10:25 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 706
Re: toilet rough-in
If it will glue on 1" you should be OK. Another option is to use an inside pipe cutter, lower the stub height more and then use a coupling with a male (spigot) flange.
Old 05-02-2016, 12:12 AM   #3
siggy312's Avatar
Rewards Points: 64
Re: toilet rough-in
ahh... knowing that a one inch glue connection with suffice may be all I need. If I cut the stub lower (below the level of the cement floor), then I would need to chisel a lot around the outside of the pipe to make room for a coupling, then put male closet into that.??? (sorry.. I used the word "union" in my original post when a think I meant coupling).
10 inch rough in, 1.28 gpf, one-piece toilet takingtoolong Plumbing 13 05-06-2014 06:10 AM
Toilet rough in size 14in or 12in? rkj Plumbing 12 02-24-2014 09:30 AM
toilet paper holder boilermaker27 Plumbing 2 09-13-2013 06:10 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 07:41 PM
Toilet rough in dilema facial Plumbing 3 01-11-2010 04:04 PM
