Toilet Relocation - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-17-2010, 01:50 PM   #1
Toilet Relocation
We are new to DIY and are planning to remodel our bathroom on the second floor of our house. We are planning to create a separate toilet room and this will require moving the toilet. We have heard this can be a problem.
We need to know what limitations we have on moving the toilet. What do we look for? We are attempting to design a floor plan but we need to know where we can and can not put the toilet and why.
Windy is offline   Reply With Quote
Old 06-17-2010, 04:07 PM   #2
Have you already chosen your new toilet? My limited knowledge with this (and relatively good luck), has taught me that each toilet has specifications for space around it for installation. When moving the line, make sure it adheres to those specs!
AZLambdaK1 is offline   Reply With Quote
Old 06-18-2010, 02:52 PM   #3
My concern is more about the plumbing and structure of the house. We have the visible space.
Old 06-18-2010, 03:04 PM   #4
Handyman
Rewards Points: 518
Need much more info and pictures would help.
What is below the bathroom on the main floor? Where did yu want to move it to?
canadaclub is offline   Reply With Quote
Old 06-18-2010, 09:13 PM   #5
jschaben
Rewards Points: 502
Hi Windy - Well, I'm not up on all the in's n' out's of a project like that either but I think the plumbing will be you biggest concern. The waste lines are usually 4" which is a lot of pipe to make room for. Supply lines aren't that large but I think you will likely need to tear out a floor or ceiling or maybe part of both. Another consideration is if the roof vent needs to be moved. That can be another bag of cats. Like others have indicated, more information, maybe even some pictures would help give better answers.
Good luck
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 06-18-2010, 09:50 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
This is not something you can research on an Internet forum. Call a local contractor.
XXX
Basement Toilet Gurgling zoner2009 Plumbing 4 01-30-2010 11:12 AM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
