Is The Toilet Flange Supposed To Be Glued Down? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 04-09-2019, 02:35 PM   #1
Rewards Points: 650
Is the toilet flange supposed to be glued down?
I'm trying to remove the old rusted out toilet fange all the nails has been removed but I can't pull it out like I did with my other bathroom. it appeared to be glued or stuck to the ABS pipe below. I've done a couple toilets now and this is the first one I ran into this problem. Is it normal for them to be glueing this? My other flanges just slide in with a gasket.
dannieboiz is offline   Reply With Quote
Old 04-09-2019, 04:50 PM   #2
Rewards Points: 268
Re: Is the toilet flange supposed to be glued down?
It could be just stuck, glued for some reason, or it could be a Twist n Set flange.
JBoot is offline   Reply With Quote
Old 04-09-2019, 04:55 PM   #3
retired framer
Rewards Points: 6,362
Most ABS are glued in the pipe.
Post a picture.
joecaption likes this.
Do not use flat bottom gables with scissor trusses.
Old 04-09-2019, 07:27 PM   #4
Rewards Points: 18,384
Nails in a toilet flange!
Old 04-10-2019, 10:59 AM   #5
Rewards Points: 2,240
You have a cast iron flange on an ABS pipe?
huesmann is offline   Reply With Quote
Old 04-10-2019, 12:59 PM   #6
Rewards Points: 7,593
All the initial install I've ever dealt with are glued either inside a 4" pipe or outside a 3" pipe.
@huesmann there are some ABS and PVC flanges that have a metal ring. Without a picture I can't declare that to be the case here.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Tile around Toilet flange. Tile will be at Higher Level than Flange? crayola110 Tiling, ceramics, marble 0 09-19-2012 07:07 PM
3" ABS toilet flange 3 1/2" too high in basement floor fusion2k Plumbing 3 08-26-2012 01:41 PM
Unleveled Toilet Flange Popped out ryanb4614 Plumbing 3 11-09-2011 07:53 AM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 09:39 PM
Toilet Flange Questions LeviDIY Plumbing 13 06-04-2009 02:22 PM
