Tips On Cutting Holes In A Kitchen Granite Counertop - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-03-2014, 10:54 AM   #1
Rewards Points: 752
Tips on cutting holes in a kitchen granite counertop
I want to add a soap dispenser to my kitchen countertop. Any tips, tricks etc. to cutting a hole in granite?
kennykenny is offline   Reply With Quote
Old 11-03-2014, 11:17 AM   #2
JUSTA MEMBER
Rewards Points: 3,632
Use a diamond bit in a drill, Slowly, keep it wet enough to keep the temperature lower,
Did I mention SLOWLY, rock the bit a little from side to side and round and round. Not overheating the bit/ hole saw, will be a slow process, but it will eventually get through.
Do not be impatient or you will break the counter top and wish that you had called the "GRANITE GUY".
ED
de-nagorg is offline   Reply With Quote
Old 11-03-2014, 11:27 AM   #3
ZZZZZ's Avatar
Rewards Points: 2,180
And measure three or four times, cut once. No second chances.
ZZZZZ is offline   Reply With Quote
The Following User Says Thank You to ZZZZZ For This Useful Post:
de-nagorg (11-03-2014)
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 11 01-03-2018 05:33 PM
Newbie Kitchen Remodel- tips or advice for cabinets/ countertops? crayola110 Kitchen & Bath Remodeling 12 03-20-2014 07:38 PM
Granite Tile vs. Laminate Countertop (Kitchen) Cow 9 Kitchen & Bath Remodeling 7 01-25-2012 11:53 AM
cutting granite myself denemante Remodeling 6 05-13-2011 12:04 AM
cutting 4" holes in 10" floor joist red_cabby Building & Construction 19 06-22-2010 04:25 PM
