Tiling Over Drywall-prime & Paint First? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Bud Cline
  • 1 Post By borzym60
Old 02-08-2015, 12:55 PM
ZZZZZ's Avatar
Rewards Points: 2,150
Tiling over drywall-prime & paint first?
Hey all,
I'm confused (yes, easily so).
I'm remodeling the kitchen and there are a couple of areas where the backsplash tile will be installed over drywall. (I put up a strip of cement board behind the sink area where it is more likely to get wet.)
On the portion of the backsplash away from the sink, should I prime (and paint?) the new drywall that will be behind the tile?
ZZZZZ is online now
Old 02-08-2015, 04:12 PM
Jmayspaint's Avatar
Rewards Points: 538
I'm curious about this too. I was taught never to deliberately paint drywall that got tile, but have seen tile put over painted walls. Is it really a big deal?
Jmayspaint is offline
Old 02-08-2015, 04:46 PM
Retired Moderator
Rewards Points: 7,174
I would prime it---the thinset could soften the drywall compound---
I've set tile over raw drywall with out any problem---but still,priming it sounds like a good idea--
oh'mike is offline
ZZZZZ (02-08-2015)
Old 02-08-2015, 06:59 PM
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The rule has always been that thinset doesn't like paint. However, and in my experience and opinion, thinset over raw drywall compound can be a bigger problem.
Over the years I have installed many backsplashes over previously painted walls without issue.
I see no reason to "prime" AND "paint" but priming is what I would recommend.
I also see no reason to install cement board in the sink area. Unless things go catastrophically wrong...you will never get enough water on the tile behind the sink to create any issues. The finished tile should be sufficiently caulked to the countertop so that pooling water (behind a sink) doesn't leach under the tile and into the drywall.
Jax2017 likes this.
XXX
Bud Cline is offline
The Following User Says Thank You to Bud Cline For This Useful Post:
ZZZZZ (02-08-2015)
Old 02-08-2015, 07:19 PM
ZZZZZ's Avatar
Thanks Bud.
I used the cement board because I happened to have a 5' long strip of the stuff left over from a previous bathroom job, so I figured why not use it for the backsplash.
ZZZZZ is online now
Old 02-08-2015, 07:30 PM
Rewards Points: 996
years ago i was told to use mastic for my tile back splash. the wall was painted. it worked really well, and is what i will be doing again.
Fix'n it is offline
The Following User Says Thank You to Fix'n it For This Useful Post:
oh'mike (02-09-2015)
Old 02-09-2015, 08:30 AM
Rewards Points: 6,887
I never use thinset on walls.
The type 1 mastic says to sand and score any painted areas. I normally draw lines on the wall about 3" short of where the tile will end and leave the tile area unprimed and unpainted.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline
Old 02-09-2015, 09:35 AM
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,020
I've had no problem either way.... remodels..repair...or new build.
For wall tile in non-wet areas, I'm fond of mastic also.... just more convenient to use.
MTN REMODEL LLC is offline
Old 02-24-2015, 05:32 AM
Rewards Points: 42
I dont understand the argument of using cement board in 'damp areas' like near the sink.
If back splash was not there, then drywall would be and fully exposed to all moisture. By covering the drywall with a backsplash you are only making it more water resistant.
And in all seriousness, a properly set back splash with grout and sealer is practically water tight.
I had to remove a subway tile from my recently done back splash because I didnt measure right. Thinset was 100% cured and set directly onto none primed sheetrock.
I was able to pry it off but it took a huge chunk of sheetrock with it. It is plenty strong when adhered directly to sheetrock.
Jax2017 likes this.
borzym60 is offline
Paint and drywall peeling off in sheets. What do I do? BustersHouse Painting 11 07-08-2013 04:42 PM
Is this drywall still usable with a skim coat & prime, or I need new one? lifan Drywall & Plaster 6 10-19-2012 07:09 PM
Peeling Paint To Drywall angelatc Drywall & Plaster 4 09-07-2012 10:52 AM
HELP - How to paint directly on drywall ceiling without cracking paint thejdoe Painting 8 04-21-2012 07:09 AM
