Tiling Newly Primed Drywall - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-22-2015, 09:43 PM   #1
Rewards Points: 22
Tiling newly primed drywall
Hi.
I will be tiling a backsplash soon, but I need to replace some of the sheetrock first.
Does it matter what primer I use as I have several partial cans available. Zinsser's BIN and their Bullseye 123.
Also, How long after priming will I be able to tile. I plan on using mastic with ceramic tile.
Thanks.
Jtom is offline   Reply With Quote
Old 11-23-2015, 06:24 PM   #2
Rewards Points: 22
To clarify my above post, basically, I am hoping I can prime on Friday, and then tile on Saturday. I have read in some other posts about letting the primer "cure", so I am not sure if I should tile that soon after I make the repair.
Old 11-23-2015, 08:14 PM   #3
Rewards Points: 392
Is priming required for mastic? I know it's not for thinset.
rustyjames is offline   Reply With Quote
Old 11-23-2015, 08:57 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 748
You may have read a comment I made about letting the primer cure. I wouldn't prime it.
I would skim-coat with the mastic, then spread the normal amount. Are the joints taped and mudded with compound? Which mastic will you be using? And the tiles are soft bisque ceramic or porcelain, or?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 11-25-2015, 07:55 PM   #5
Rewards Points: 22
Thanks for the replies.
I have never tiled before, so when I think of putting up drywall, I just assumed I would prime it before moving on.
Jaz, after researching a little more, I learned that the adhesive I will be using (Acrylpro ceramic tile adhesive) is okay for drywall, with no mention of priming. I am going to use a non-vitreous, glazed ceramic wall tile from HD, and I do not plan on taping as it is a small area, and I will cut the replacement piece to fit fairly snug, possibly adding some sistering for support.
Thanks again,
Jeff
Old 11-25-2015, 10:21 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 748
Jeff,
You need to tape all joints. Go ahead and use the mastic when taping then just skim the rest of the tile area.
Jaz
Old 11-25-2015, 10:53 PM   #7
Rewards Points: 22
Sounds good. I will do that.
Thanks,
Jeff
do you have to tape joints? begal Drywall & Plaster 34 08-09-2015 08:42 AM
Drywall Repair Prior to tiling jenkinsdanita General DIY Discussions 7 07-02-2015 07:53 AM
Tiling bath tub surround- regard? Tar paper? Green drywall? Wonder Board? crayola110 Tiling, ceramics, marble 13 05-11-2015 07:22 PM
Primed new ceiling drywall logcabinorchard Drywall & Plaster 3 01-23-2013 07:04 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
