Tiling Behind Wall Hung Toilet? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-11-2015, 04:05 PM   #1
Rewards Points: 636
tiling behind wall hung toilet?
I've decided to go with a wall hung toilet for our bathroom remodel. The design calls for a full wall tile. Assume everything is properly plumb and level, how likely is the tile to crack if the toilet was mounted in front of it?
dannieboiz is offline   Reply With Quote
Old 11-11-2015, 04:56 PM   #2
Rewards Points: 469
What type of carrier are you using
Jnaas2 is offline   Reply With Quote
Old 11-11-2015, 05:01 PM   #3
Rewards Points: 636
plan on using Geberit 111.728.00.1 for a 2x4 frame installation.
Old 11-11-2015, 05:06 PM   #4
Rewards Points: 144
It should have no effect on the tile if the tile and toilet are properly installed.
mako1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mako1 For This Useful Post:
dannieboiz (11-11-2015), oh'mike (11-11-2015)
Joining thin wall abs pipe to standard abs pipe Homerepairguy Plumbing 3 03-01-2015 11:39 PM
Wall prep for kitchen wall tiling GDower5510 Drywall & Plaster 4 05-22-2012 08:52 PM
Toilet tank 1.5" from wall syogod Plumbing 13 10-20-2011 07:35 PM
wall mounted residential toilet kr bennett Plumbing 10 12-05-2010 10:03 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
