Tiled Wall For Glass Shower Door Is Not Plumb. Suggestions? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-30-2020, 10:52 PM   #1
Rewards Points: 6
Question
Tiled wall for glass shower door is not plumb. Suggestions?
I didn't start with a perfect wall (long story -guy who got it ready for tile is long gone) and didn't realize the impact the non-plumb wall would have on framing in the glass shower door.
This is an alcove bath/shower. Tile is 4 x 16" ceramic, so soft to work with. One bottom row tile throws it off at the far end of the tub enough that shimming the shower door frame with some washers and siliconing where there would be a gap would look bad. I've got two rows at the shower head side.
I'm hoping someone has used something like a diamond ball end bit on a dremel to shim down tile height before on a wall. I just need a 1/2' channel ground down to plumb out the wall.
Anyone???
saltare is offline   Reply With Quote
Old 07-01-2020, 10:31 AM   #2
Rewards Points: 5,068
Re: Tiled wall for glass shower door is not plumb. Suggestions?
I assume using a U-channel for the edge of the glass is out of the question, aesthetically?
Edit: pics are your friend.
huesmann is offline   Reply With Quote
Old 07-02-2020, 01:14 AM   #3
Rewards Points: 6
I'm new to the forum and must have a post under my belt before I can post pics/links.
The shower door is Levity 60 in. x 62 in. Semi-frameless Sliding Tub Door in Silver with Handle. (Home D)
I'd love to show the amount the lower tile row throws off the plumb line if it would allow. Sigh. The rest of the job is not too bad and I used a laser so my stacked lines would be decent. Just a total DIY oversight IF I was going to use a shower curtain, all would be fine. I have the shower door waiting n the garage though.
Old 07-02-2020, 11:09 AM   #4
So this one?
https://www.homedepot.com/p/KOHLER-L...L-SH/203925281
Old 07-02-2020, 03:03 PM   #5
Rewards Points: 6
Yes, that's the shower door.
I found a great video on-line where they used a 6mm ball point super coarse diamond bit to shave down a bit of tile, but I can't seem to find the bit to purchase.
Tags
fix tile wall , grind tile , non-plumb wall , shower door install , tile
