Tileboard Tub Surround Transition Caulking - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-08-2015, 07:59 AM   #1
Rewards Points: 30
tileboard tub surround transition caulking
I got an odd situation with the transition between our one piece tub surround and the tileboard I installed above it. The tilebard was installed over drywall and is completely out of the shower spray area but will be exposed to minor splash and humidity, therefor it is imperative to seal the edges well with caulk. This is not a problem except for about a 2 foot section at the middle of the back wall where, because of the surround's profile it dips to about 1/16" lower than the level of the tileboard which will make calking almost a reverse of the normal corner caulking. Normal tooling of the caulk at this point will only barely cover the uncoated edge of the tileboard. Anyone have any ideas! It's almost like I need to make a convex bead of caulk at this section to achieve at least a 1/8" overlap of the board edge. Thanks for any ideas.
scottfarkus is offline   Reply With Quote
Old 12-08-2015, 08:38 AM   #2
Rewards Points: 17,890
Hard to know without seeing it, picture would help.
Just got to ask, why the tile board over drywall?
Old 12-08-2015, 07:00 PM   #3
Rewards Points: 30
drywall was old and paint peeling. Pevious owners apparently didnt use primer on the fresh drywall. Used a scraper to remove old paint and created lots of gouges. This was the best fix over ripping out and replacing drywall.
Caulking Shower Surround KUppiano Plumbing 1 12-03-2012 07:15 PM
Questions about caulking changes of plane in a tiled tub surround? amodoko Plumbing 2 03-18-2012 10:39 PM
Caulking an Acrylic Shower Surround jake_7363 General DIY Discussions 1 10-23-2011 07:51 PM
Shower Surround & drywall transition mchull Drywall & Plaster 5 08-19-2010 03:31 PM
