regeisle |
03-29-2012 07:17 PM |
tile tub surround - existing insulation has vaporbarrier
1 Attachment(s)
Long story short, I'm ripping out some blueboard in basement for a future tile tub sorround and replacing with 6mil plastic and CBU. Or that was the plan. I just ripped out some of the back wall and realized (remembered) that the builder had installed insulation around all outside walls. I don't recall the type of insulation, but it seems to be faced batts with a white plastic sheet on top that spans the whole wall, not just stuffed between studs. This is only on the back wall, not the sides. So that brings me to the question... what should I do on this back wall? See attached pic for what is there. It's in fairly good shape other than the square i punctured out with the drywall saw when starting this process and a few small rips and holes, but that could easily be patched. If I just apply the 6mil over that, I assume Id then be stuck with the no good moisture sandwich.
Should I just use what's there (patched) as the back vapor barrier and then attach and extend the plastic on each side for left and right walls. Or I could remove the plastic and paper face from insulation behind the entire tub area where the CBU is going and stick to the original plan. Or is that space (none, really) between the 2 plastics not enough to cause a moisture lock issue? Any other ideas? Right now I'm stuck on what to do next. Thanks!
Rich
