Tile Size Guidelinss For Shower - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-14-2013, 08:32 AM   #16
bryanp22's Avatar
Rewards Points: 346
Had a question on vapor barrier. My shower is on an outside corner of a wall. Any recommendations then to avoid condensation?
bryanp22 is offline   Reply With Quote
Old 06-14-2013, 08:50 AM   #17
Bill Kearney
Rewards Points: 1,174
Correct me if I'm wrong but If you're using redguard or another wet application moisture barrier then that would be sufficient. Otherwise you'd be encasing the backer between two barriers and potentially having moisture collect inside of it, leading to it failing sooner.
wkearney99 is offline   Reply With Quote
Old 06-14-2013, 09:36 AM   #18
bryanp22's Avatar
Rewards Points: 346
Okay, I just apply that to the cement board correct?
Old 06-14-2013, 12:41 PM   #19
Bill Kearney
Yep, the stuff just paints on. Looks like something out of a horror movie with all that red goo on the walls. I seem to recall using a combination of a flexible spackling spatula (4", I believe) and brushes. Just BE SURE to clean those brushes quick otherwise the stuff dries hard and they're toast.
tile size laorquidia Flooring 16 09-17-2012 08:54 PM
Does Tile Size Make A Room Look Bigger or Smaller? DrHicks Tiling, ceramics, marble 13 10-12-2011 08:51 PM
Nominal Size of Tile, Lowes/HD vs Tile Store Thadius856 Flooring 17 09-12-2011 08:16 PM
tile size shappire Tiling, ceramics, marble 2 09-11-2011 10:24 PM
What size floor tile? skipjack Flooring 1 09-22-2008 10:39 AM
