Tile Before Cabinets, Cabinets Before Tile? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-22-2017, 11:12 AM   #1
Rewards Points: 87
Tile before cabinets, cabinets before tile?
After about 5 years of talking about it, I have finally decided to remodel our very small kitchen in our small 1943 home.
What we have currently (from PO's) is an engineered laminate floor that is sitting on top of the original hardwood floor. If I were a betting man, I would say there is also a "nice" 60s-70s era vinyl sheet in between the 2 (nice being sarcastic of course)
When the PO installed the engineered hardwood, they left the cabinets in place, and just made the cuts as needed to fit around the cabinets.
The cabinets are really cool original 40s era stock and my wife wants to keep them and sand and repaint them and I am cool with that, saves a ton of money.
We only have 3 sections of cabinets that are quite small - a 1' X 3' section, a 3' X 3' section and then a longer 7' X 3' section,where the sink and other cabinets are. (The smaller sections are actually free standing, I plan on actually installing them properly after this.
I think we are leaning towards porcelain so the question is - should I lay floor and put the cabinets on top, or put the cabinets in first and lay floor around it. I think we are going with porcelain. Thanks!
shelzmike is offline   Reply With Quote
Old 02-22-2017, 11:59 AM   #2
Rewards Points: 1,054
Re: Tile before cabinets, cabinets before tile?
I always set tiles to the walls and install cabinets/vanities over the tile. I sometimes use scrap tile for some of the area under the cabinets in the kitchen.
Can you piost pics of the cabinets, inside and out? I enjoy seeing old stuff like that.
clarenceboddick is offline   Reply With Quote
Old 02-22-2017, 07:43 PM   #3
Rewards Points: 62
If you're going to remove them AND your floor is flat, tile the whole thing. If its not, put them back in and tile up to them.
rockmup is offline   Reply With Quote
Old 02-23-2017, 02:17 AM   #4
jlhaslip's Avatar
Rewards Points: 708
I might also make sure that the finished height of the counter top ends up at 36 inches from the finished floor.
Might need to add something to the bottom of the cabinets depending on the thickness of the tile install.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Cabinets To Go! CapnHawk Kitchen & Bath Remodeling 69 08-13-2017 06:02 AM
Cabinets over tile, or tile around cabinets??? harleysilo Remodeling 10 11-02-2012 01:25 PM
Refinishing old Cabinets ryanb4614 Carpentry 4 08-18-2011 06:24 PM
Changing Kitchen Flooring from tile to Hardwood? Regarding taking cabinets up? doodleb1973 Flooring 3 07-27-2011 05:25 AM
A middle of the road choice for tile first or cabinets first Cecosugi Flooring 3 08-20-2009 12:02 PM
