Tile Around Window And Proper Transition - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By TarheelTerp
Old 11-02-2018, 09:13 PM   #1
Rewards Points: 160
Tile around window and proper transition
What started as casual shower tile grout refresh as turned into a gut job after discovering old moisture damage. House was built in 62', utilizing the mesh, mortal and plaster method of old. Tearing it all out down to the studs, replacing with Hardie 500 and Kerdi membrane. Making all the proper repairs before sealing walls, then on to the backer board install and hopefully tiling next weekend.
I'm curious how to tile and transition properly into the window sill. There's not enough space to tile the sill, so I'll need to determine a proper method to so that will be waterproof. Obviously, the wooden trim (who thought that was a good idea, even if coated?) will be removed. Would bullnose, grout and caulk work?
All the videos and tutorials I've discovered cover tiling the actual seal. We're using 3x6 tile for reference.
Tile around window and proper transition-img_20181102_204311921.jpg   Tile around window and proper transition-img_20181102_204318426.jpg
oblvnnwtnjhn is offline   Reply With Quote
Old 11-03-2018, 05:00 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,548
Re: Tile around window and proper transition
Is there a shower involved? If so, I would remove the window trim and existing tile and bed. Then post pictures of what you have. Most likely you can tile inside the window frame provided you prepare it first and slope the tile slightly for water run off. Yes, you would use a bullnose tile to transition it.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 11-03-2018, 06:52 AM   #3
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,120
I won't go so far as to say it's proper...
but this worked out rather well.
I added some wood around the window to deepen the 'sill'.
MR-GWB with vinyl J channel up to the window frame; caulked.
Simple round edge tile set between the window and wall.
RedGard on all wallboard and Epoxy on the exposed walls.
Johnny_inFL likes this.
Old 11-03-2018, 07:15 AM   #4
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,228
when done "correctly", wood window trim will work.
no difference than having the same trim on the outside of your house.
[a thorough understanding of wood types, sealants, paint and caulk is a must].
a good alternative for wood trim in the bath is PVC material.
Johnny_inFL is offline   Reply With Quote
Old 11-03-2018, 08:27 AM   #5
hkstroud's Avatar
Rewards Points: 5,748
I think i would consider trimming that window with marble.
Google "window trim marble"
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 11-03-2018, 09:22 AM   #6
Rewards Points: 160
thanks gents for the replies. Once I get the backer-Kerdi in, I'll take some time to study the methods proposed.
Proper sealing of block to window frame. Trucon01 Windows and Doors 5 11-14-2012 02:36 PM
Changing Window Size TinaV Remodeling 3 11-06-2012 12:30 PM
Need to determine proper Basement Window Header size- AdamH Building & Construction 1 11-23-2011 02:59 PM
Need Advice For Fun Project - liberating stained glass window jackson33 Building & Construction 9 03-08-2011 04:09 PM
Proper Vinyl Window caulking With Hardi-plank fitzofury Remodeling 2 04-26-2010 01:33 PM
