Tile Application Technique? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-17-2011, 08:47 AM   #1
Question
tile application technique?
When tiling my new shower stall, how do I apply the thinset between the tile and the concrete backerboard? Do I apply the thinset to the concreteboard, groove it with a 1/4" notched trowel and then press the tile to that? Or do I have to 'backbutter' the tile as well prior to pressing into the grooved thinset?
lizardrider is offline   Reply With Quote
Old 05-17-2011, 01:17 PM   #2
Rewards Points: 5,348
You first need to use the correct notch pattern and size for the tile. You would use different notched trowels for different size tiles. The thinset bag will have a chart to guide you.
You apply the thinset to the wall with the flat side of the trowel first, getting a good bond to the substrate. After you have as much on the wall as you want, turn the trowel around and hold it at a 45 degree angle to the wall and notch the thinset evenly. If some of the ridges aren't full, renotch that area. When it's all uniformly notched, start applying tile.
You don't need to back butter small, flat backed tiles or mosaics.
Since you didn't ask, I assume you know how to lay out the wall and where to start tiling.
The John Bridges Forum will give you a good overview of the process.
Ron
Subfloor and Porcelain tile prep sugarhousemama Flooring 4 12-03-2010 06:47 PM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 03:06 PM
Where do I make my tile cuts for the wall? petsparkle Kitchen & Bath Remodeling 6 04-25-2009 10:00 AM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
