Threaded Light Globe Won't Budge - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree14Likes
  • 3 Post By Guap0_
  • 3 Post By Bud9051
  • 1 Post By Nealtw
  • 1 Post By de-nagorg
  • 2 Post By SeniorSitizen
  • 1 Post By u3b3rg33k
  • 3 Post By LadeeDIY
Old 08-12-2018, 12:48 PM   #1
Rewards Points: 136
I put back this threaded light globe in the socket. I put it in wrong. Now I cannot get it out. I've tried turning it clockwise, counterclockwise. I have sprayed the thread with Blaster. It won't move.
Should I break the globe? Behind it is a plastic fixture which is screwed in using Allen screws which I want to remove. Behind the plastic fixture is the actual electrical that stays. I have attached pics so you can see.
Or is there anything else I can try? Breaking this thing is the last resort. I don't want to do this and have glass shards all over.
Thanks for any suggestions.
LadeeDIY is offline   Reply With Quote
Old 08-12-2018, 01:06 PM   #2
Guapo
Rewards Points: 11,950
Re: Threaded Light Globe Won't Budge
You cross threaded it. Throw a rag over it so if it breaks, the glass won't fly. Put on some heavy gloves & a pair of safety glasses. Grab it tightly & spin it counter clockwise.
Don't be afraid to use some force.
Dave Sal, de-nagorg and LadeeDIY like this.
Guap0_ is offline   Reply With Quote
The Following User Says Thank You to Guap0_ For This Useful Post:
LadeeDIY (08-13-2018)
Old 08-12-2018, 02:33 PM   #3
Rewards Points: 5,826
If a risk of breaking I would cover the glass 100% with strips of duct tape, makes it easier to get a hold of as well.
One other step you might try would be a hair dryer. Heat can make metal expand and maybe loosen it up.
Bud
Bud9051 is offline   Reply With Quote
Old 08-12-2018, 02:46 PM   #4
retired framer
Rewards Points: 18,874
I would just put a bag over the globe and break it.
LadeeDIY likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
Old 08-12-2018, 03:57 PM   #5
JUSTA MEMBER
Rewards Points: 3,672
I would put on thick leather gloves, and grab it with my Gorilla Paw, and unscrew it, the gloves are in case it breaks, don't want to sever my carpal artery.
Sometimes a rubber jar lid opener, from the kitchen will give you better grip to unscrew it.
It's cross threaded, and stuck.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Old 08-12-2018, 05:06 PM   #6
Rewards Points: 1,466
If you lived next door I'd loan you my 6 ft. x 6 ft. piece of rubber shelf liner to wrap around as a gripper, apply some torque lefty loosie and put the hair drier heat to it while torque applied.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 08-12-2018, 11:16 PM   #7
Rewards Points: 1,086
if you haven't broken it trying, you're not trying hard enough. Turn it like you mean it. it'll either come out or break.
Nealtw likes this.
u3b3rg33k is online now   Reply With Quote
Old 08-13-2018, 07:17 PM   #8
Rewards Points: 136
Yay! Success at last. I kept turning it counter-clockwise. It loosened a bit, so I turned it both ways. It took about 6 tries but it simply screwed off like a miracle on the lasts try. No break and the globe is perfect. However, am replacing the whole fixture.
Thanks for all your suggestions. Very much appreciated! :-)
Tags
bathroom light fixture , lighting fixtures , problems
Aluminum foil inside light globe Taffyo Electrical 3 05-27-2018 07:31 PM
Hard Wiring vanity light fixture into outlet? qwiksilvertrav Electrical 16 02-24-2013 01:16 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
