Thinset Tile Adhesion - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-26-2015, 08:26 AM   #1
Rewards Points: 2
Thinset tile adhesion
Hi!
I'm new to the forum, so pardon me if I'm posting in the wrong spot. I recently started remodeling my bathroom, and I'm tiling the walls with ceramic subway tiles.
I have a questions regarding thinset and tile adhesion. I used cement board and used Redguard to waterproof. I mixed the thinset as recommended, but I guess I'm just a little worried (since I don't have any experience with tiling) that a year from now the tiles will be falling off the wall because I did something wrong.
One thing I'd like to mention is that as I was working and the thinset started to get a little thicker, I would add a bit of water and remix with a margin trowel. I did this every 30 minutes to keep the thinset the proper consistency. I was constantly mixing the thinset so it would skim over in the bucket.
Anyway, I'm just a little nervous that I did something wrong. Do you all ever test the adhesion? Like try to pop a tile off or something? Probably sounds like a stupid question, but just curious. Also, probably too late to fix any issues too. I guess I'm just looking for peace of mind really
Thanks,
Matt
mattyoungus is offline   Reply With Quote
Old 05-26-2015, 02:06 PM   #2
Rewards Points: 474
No you’re good; a lot of times you mix a small batch, when that is used up you mix more.Remixing the same stuff over and over by adding water weakens it.
BrowneBearLLC is offline   Reply With Quote
Tags
thinset , tile
1/4 hardie backer over subfloor, then thinset and tile? vestaviascott Tiling, ceramics, marble 10 12-16-2014 10:20 PM
What type of thinset for Porcelain tile? BlueBSH Flooring 13 05-12-2013 10:53 PM
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
Mastic or thinset for decorative glass tile mosaic? gtothek Kitchen & Bath Remodeling 1 09-28-2012 06:33 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
