Starting My First Tub-to-shower Conversion! - Kitchen & Bath Remodeling - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree5Likes
Old 02-13-2016, 11:14 AM   #31
WhatRnsdownhill's Avatar
Rewards Points: 2,220
that looks good, with a slight slope, but not enough to make the strainer crooked...
WhatRnsdownhill is offline   Reply With Quote
Old 02-13-2016, 03:36 PM   #32
Retired Moderator
Rewards Points: 7,174
That's the ticket----1/4" per foot drop is the standard---
Old 02-14-2016, 10:32 AM   #33
Rewards Points: 996
ok, i have a question, not to jack this thread.
why can't the trap be left where it is/was ?
Fix'n it is offline   Reply With Quote
Old 02-14-2016, 10:43 AM   #34
Retired Moderator
A trap in the line is called a 'running trap'--and has two very real problems--
1. they can be sucked dry (by siphoning) allowing sewer gas to enter the building--
2. they allow sludge and hair to drop and cause a blockage---this is a very likely failure --and rather hard to rod--due to the double bend.
Fix'n it (02-14-2016)
Old 02-14-2016, 10:52 AM   #35
Rewards Points: 996
ok, makes sense.
oh, and thanx = for not saying, "because thats not the right way".
Old 02-14-2016, 11:01 AM   #36
if you had to leave the trap in its original location it would work and if properly vented and with a pvc trap I wouldnt be too worried about any siphonage effect, and again with pvc build up of debris and trouble rootering it is negligible...but if its doable to put the trap under the strainer, that would be better..
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
oh'mike (02-14-2016)
Old 02-14-2016, 11:53 AM   #37
Retired Moderator
There are several 'IFs' in this post---
So--doing it correctly may cost $10 in parts and perhaps an hour---or even two--
'IF' the work fails----the new base ,tile work and slab will need to be removed and rebuilt----
As Clint Eastwood would say, "Are you feeling lucky?"
Old 02-14-2016, 12:07 PM   #38
thats why I said IF..the trap could not be moved...
Old 02-15-2016, 09:15 PM   #39
Rewards Points: 80
Ok, before I actually apply glue, does everything look ok?
chakotay is offline   Reply With Quote
Old 02-16-2016, 05:07 AM   #40
Retired Moderator
That looks right to me----
Old 02-16-2016, 05:13 AM   #41
A "Handy Husband"
rjniles's Avatar
Rewards Points: 606
The flange should be set high enough to end up on top of you finished floor.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 02-16-2016, 06:18 AM   #42
Retired Moderator
That is a shower pan clamp drain--
Old 02-16-2016, 06:29 AM   #43
A "Handy Husband"
rjniles's Avatar
Rewards Points: 606
Oops, that's what I get for not reading😨 Or even looking very closely.
The Following User Says Thank You to rjniles For This Useful Post:
oh'mike (02-17-2016)
Old 02-16-2016, 07:09 AM   #44
coffee time...
looks good glue er up..
Old 02-16-2016, 09:48 AM   #45
Rewards Points: 80
Correct, It's a clamp drain. There's a couple of pieces that go on top. I presumed the bottom flange should sit as low as possible (in this case slightly below the floor surface. But should it be high enough to sit on top (or flush?) of my pre-slope? It seems like my pre-slope will be paper-thin by the time it reaches the drain otherwise. But maybe that's ok?
Also, can I fill the hole with sand, then top it off with concrete (to the thickness of the slab) when I'm done?
Do I need to leave space around the bottom flange? Or or do I literally concrete it in?
Shower Panel Install Gone Wrong Bushido_Ben Plumbing 10 11-03-2013 07:23 AM
Shower Leak Herk_Man Plumbing 10 04-14-2013 04:19 PM
Shower Rough In - Miscellaneous Questions tev9999 Plumbing 1 02-13-2012 09:40 PM
tub to shower conversion for wheelchair lmatl Plumbing 5 09-01-2010 08:06 AM
shock in shower tbwoods Electrical 64 07-23-2009 11:26 AM
