Soundproof Sink? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joecaption
Old 06-18-2018, 09:03 AM   #1
PPBART's Avatar
Rewards Points: 1,243
Soundproof sink?
I installed a standard drop-in stainless double-bowl sink in the condo kitchen. It supposedly has "soundproofing" on the underside, but really whatever that white coating is might as well be paint when it comes to noise reduction. Is there some way (e.g., spray-on foam?) to quieten it down?
PPBART is offline   Reply With Quote
Old 06-18-2018, 09:46 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,050
Re: Soundproof sink?
Good inquiry.... IDK
On a double bowl SS sink, I sprayed between the bowls with poly foam... it seemed to help some....
MTN REMODEL LLC is offline   Reply With Quote
Old 06-18-2018, 09:49 AM   #3
retired framer
Rewards Points: 18,610
cover the bottom with peel and stick. May need primer.
Nealtw is offline   Reply With Quote
Old 06-18-2018, 05:11 PM   #4
Rewards Points: 17,890
I use vehicle undercoating.
https://www.eastwood.com/flexible-se...6-oz-aero.html
MTN REMODEL LLC likes this.
Drain Route and Venting for new kitchen sink drain (window above sink) joemc3 Plumbing 12 11-05-2016 06:17 PM
Peninsula Sink removing Pony wall becomes Island Plumbing? lothia Plumbing 6 04-30-2013 12:13 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
disposal sink flange without the disposal? wolfv Plumbing 2 04-29-2010 06:24 AM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 03:12 PM
