Some Bathroom Design Questions - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 11:33 AM   #1
Work Hard, Play Harder
Rewards Points: 212
Some bathroom design questions
Hey guys, small/quick questions I haven't been able to google...
1) I was searching the Wisconsin codes (SPS 321 is correct document?) and I can't find anything about minimum bathroom size, etc. I'm looking for the toilet spacing, sink spacing, etc. I'm looking to change a large bathroom to a smaller one; to make room for a closet in the room next to it.
2) What is your opinion on shower ceilings? Do the extra work and tile it too? Don't want to just have drywall up there (plan to tile the rest).
3) to save money for the master bath shower; I plan to tile it (curb, etC); and then have a shower curtain for a bit, adding the glass later. Will that be a problem?
Thanks!
coderguy is offline   Reply With Quote
Old 03-02-2012, 12:18 PM   #2
Rewards Points: 17,890
No idea what your local codes are but here's some rules of thumb.
http://www.us.kohler.com/designkb/de...ceplanning.jsp
Old 03-02-2012, 12:37 PM   #3
Rewards Points: 81
Thanks!
1. I don't know that there are minimum square footage requirements for a bathroom, but there are minimum ceiling heights and there are absolutely requirements on spacing of toilets, sinks, etc.
2. I like tiled shower ceilings, but the catch here is the structure above it. To tiling a ceiling means quite a bit of weight pulling down on the joists. In my area, tiling overhead requires joists to be 16" OC max.
3. I can't imagine a curtain will be a problem. Just make sure you design the shower with a glass enclosure in mind. Glass is heavy and the hardware requires solid surfaces to anchor into.
JeepNick is offline   Reply With Quote
Old 03-02-2012, 12:43 PM   #4
Rewards Points: 6,652
My bath is aprx. five 1/2 feet by twelve feet, with eight foor ceilings. We have a thirty inch cabinet vanity in there, toilet is centered between it and the tub.
Old 03-02-2012, 02:34 PM   #5
Residential Designer
AndyGump's Avatar
Rewards Points: 868
Send a message via Skype™ to AndyGump
Check out THIS link from the 2009 IRC and THIS one too.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
coderguy (03-02-2012)
Old 03-02-2012, 03:34 PM   #6
Rewards Points: 212
Andy.
The first link is perfect!
As for the second, I don't think a bathroom counts as habitable???
R304.3 Minimum dimensions: Habitable rooms shall not be less than 7 feet (2134 mm) in any horizontal dimension.
I know many many bathrooms that are a lot smaller than this?
Old 03-02-2012, 07:14 PM   #7
Rewards Points: 81
Correct
"Habitable Space: A Space in a building for living, sleeping, eating or cooking. Bathrooms, toilet rooms, closets, halls storage or utility spaces and simliar areas are not considered habitable spaces."
Old 03-29-2012, 01:10 AM   #8
Designer bathrooms
Thanks!
sounds like a good plan you got there. definitely tile/water proof paint the shower ceiling for a safer roof over your head.
designer bathrooms
philjones is offline   Reply With Quote
Bathroom Venting/Waste design outline AJA Plumbing 2 12-02-2011 01:38 PM
Basement Bathroom Rough In Questions Mike Fox Plumbing 10 11-10-2011 08:35 AM
Bathroom is gutted, and a few questions Fisher252 Kitchen & Bath Remodeling 12 10-10-2011 02:48 PM
Bathroom remodel questions. What a mess now timewarp Remodeling 5 01-14-2009 04:43 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 07:59 AM
