Soffitt Above Tub - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-02-2016, 05:59 PM   #1
jkk
Rewards Points: 317
Soffitt above tub
This home is 45 years old. There's a soffit abive the tub/ shower. Why did they put these in? Is it because the std enclosures are 7'? Are they needed for any other reason? It seems to be coated in a foil material.
I'd like to raise the ceiling up to the truss chord. Any reason not to?
Thanks.
jkk is offline   Reply With Quote
Old 05-02-2016, 07:08 PM   #2
Rewards Points: 17,890
Re: Soffitt above tub
Could be a chase for wiring, HVAC, rafters in the way.
Only way to know is get in the attic and see what's going on.
Old 05-02-2016, 10:13 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 748
They built the soffit for the appearance, most people think it looks better. There's a good chance that once it was framed, the electrician may have run wires inside it instead of over the ceiling joists, but who knows? I doubt there's any HVAC there, that would make no sense unless you see the same soffit in the next rooms too.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
fireblocking of soffitt boilermaker27 Building & Construction 2 02-26-2014 12:08 PM
removing insulation from soffitt drdog54 Insulation 1 05-06-2012 06:07 PM
soffitt installation infoman Building & Construction 1 08-20-2011 04:05 AM
Tips for repainting metal soffitt Dan Haneline Painting 2 04-21-2009 03:21 PM
How to hang screws from soffitt - the underside of the outer edge of the roof Synthia212 General DIY Discussions 5 03-10-2009 05:08 PM
