Which Size Subway Tile? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-28-2018, 09:55 PM   #1
Mike Milam's Avatar
Rewards Points: 152
Which size subway tile?
In my ongoing project replacing a whirlpool tub with a different whirlpool tub, I plan to tile the walls surrounding the new tub up about 18 inches in white subway tile. I'm trying to get in my minds eye what size would be best. The big box stores have it listed on their web sites in 3 X 6 inch. I'm concerned that for the small area I'm doing, that tile may look too big. I'm sure someone would have 2 X 4 or something like that. Which in your opinions would look more to scale given the area to be tiled? Thanks
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Old 03-29-2018, 01:54 AM   #2
Peace be with you
DR P's Avatar
Rewards Points: 1,860
Re: Which size subway tile?
I think both will look fine but
I would go with which tile has best layout options for
your perimeter between tub dam & corners at walls...
are you using a bull nose to frame perimeter or what?
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
Old 03-29-2018, 05:12 AM   #3
Rewards Points: 1,406
I think with the short wall being in place, the 3" x 6" tiles will fit more pleasing to the eye "dimensionally" than any shorter in length tiles. BUT, the end wall will be an issue will the longer tiles to do. JMO though
Gregsoldtruck79 is offline   Reply With Quote
Old 03-29-2018, 05:55 AM   #4
Do I get to change my mind since my edit time ran out ? My goofy sketch shows the end wall facing tiles using 3" x 6" may look odd. So you may be spot on going with a more rectangular look for the tiles. JMO though...
P.S. I hope you can lay tiles better than I can draw them this early in the morning.
Old 03-29-2018, 06:00 AM   #5
retired framer
Rewards Points: 18,480
I was born a cheapskate if the look is similar I would go with the cheaper, they will all be out of style in a few years anyway.
Old 03-30-2018, 08:20 AM   #6
Mike Milam's Avatar
Rewards Points: 152
While we're on the subject of tile, when you cut the glazed white ceramic tile on the wet saw, do you cut face up? or down? Also, when I did our backsplash in the kitchen, it seemed what ever I marked the tile with disappeared as soon as the saws water started running over it. What is best to mark the tile so the line doesn't go bye-bye? Thanks
Old 03-30-2018, 09:35 AM   #7
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,020
You cut face up.... If I'm not jigged up and have to follow a line... I use blue painters tape on the tile and mark on that.
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Mike Milam (03-30-2018)
Old 03-31-2018, 03:57 AM   #8
Rewards Points: 382
Get a China maker. Sold near tile supplies. It's like a wax pencil
Erico is offline   Reply With Quote
The Following User Says Thank You to Erico For This Useful Post:
Mike Milam (03-31-2018)
Old 04-08-2018, 08:09 PM   #9
Mike Milam's Avatar
Rewards Points: 152
Well, the tile is done and grouted. I'm going to seal the grout in the next day or two. Question: I figured on using a foam brush and hit just the grout lines. How critical is it to get the sealer off the glazed tile?
subway tile trim question spatn Kitchen & Bath Remodeling 3 02-09-2018 11:48 PM
Removing old tile and putting up new. Few question. Whyjune1st Remodeling 8 09-10-2014 12:36 AM
tile size laorquidia Flooring 16 09-17-2012 08:54 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Best way to get level horizontal rows with subway tile? mrpurty Tiling, ceramics, marble 1 03-26-2009 07:58 PM
