Sink Drain Gasket. What Size - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By RRH
Old 02-28-2019, 12:59 PM   #1
Rewards Points: 755
Sink Drain Gasket. What size
I purchased a vanity and now trying to install the faucet and drain. I noticed the gasket for the faucet/drain does not fit properly. I would think the gasket would sit inside the drain part. In the photo, you can see that the gasket is a bit wider than the opening. Is this common when purchasing faucets? and is an appropriate size gasket available at the big box stores? or do I need to order it online.
Sink Drain Gasket.  What size-20190227_133752.jpg   Sink Drain Gasket.  What size-20190227_133933.jpg   Sink Drain Gasket.  What size-20190227_133736.jpg
greentrees is offline   Reply With Quote
Old 02-28-2019, 02:29 PM   #2
Rewards Points: 2,273
Re: Sink Drain Gasket. What size
Not sure where your confusion is coming from. The tapered rubber gasket gets pinched and squeezed between the bottom of the sink drain and the threaded flange, creating a watertight seal.
huesmann is offline   Reply With Quote
Old 02-28-2019, 03:27 PM   #3
RRH
Rewards Points: 1,316
Like other post said. You are fine and have the correct one. Does not fit inside and lay perfectly flat like you may have seen on a normal flat washer.
RRH is offline   Reply With Quote
Old 02-28-2019, 04:08 PM   #4
Rewards Points: 755
Looking at the gasket, I wasn't sure if it is considered tapered. The raised part of the gasket is larger then the drain opening. Would I need to use teflon tape on the threads and plummers puddy above the gasket?
Sink Drain Gasket.  What size-20190228_132249.jpg   Sink Drain Gasket.  What size-20190228_132254.jpg
Old 02-28-2019, 06:37 PM   #5
RRH
Again you are fine millions have been used and you would be hard pressed to find anything different. And why.
Plumbers putty under the flange top inside the sink. Nothing on the gasket under the sink or on the threads.
Although I am a bit picky and always add a Teflon pipe dope on the top of the gasket were it meets the sink. But again not needed. A little messy and I had maybe 1 out of 50 that leaked. Rare times the sink had a small flaw or something and had a hard time getting a good seal. Pipe dope solved the prob and I just got in the habit of using it.
joecaption likes this.
Old 02-28-2019, 07:05 PM   #6
Rewards Points: 755
Need to pick up some Plumbers Putty. The faucet instructions said to use Silicon under the flange but assume Putty is better.
The main concern is the overflow, where water would sit on top of the gasket, not completely draining since the holes in the photo are likely to be high above the gasket. But assume this is normal.
Old 03-05-2019, 09:51 AM   #7
The putty is easier to remove when something needs replacing.
Major issues fitting new drain to bathroom sink. ben_allison Plumbing 6 11-15-2015 08:44 PM
Condensate Drain Line Mystery FrogFan HVAC 5 09-24-2015 09:27 PM
Island sink drain problem oldphoneman Plumbing 2 02-06-2012 10:56 PM
Condensate draining into sink drain fritzycat1 HVAC 0 01-23-2011 01:39 AM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 05:36 PM
