Silicone Removal From Bathtub Ledge - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By SPS-1
Old 05-15-2016, 12:33 PM   #1
jlhaslip's Avatar
Rewards Points: 708
Silicone removal from bathtub ledge
My daughter, bless her heart, has removed a sliding door from her bath tub and scraped (as best she could) the silicone from the tub and surround, however, there remains a skim of silicone which I am sure will present problems in the future.
I followed up with a razor blade to scrape some more of the silicone off, but am still not happy with the results.
Is there a liquid which will remove the remainder of the silicone from the tub and surround which will not damage the surround?
Thanks.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 05-15-2016, 01:34 PM   #2
Rewards Points: 7,188
Re: Silicone removal from bathtub ledge
I don't think there is a "remover" that will dissolve the silicone. Products such as this one soften the silicone to make it supposedly easier to remove. http://www.canadiantire.ca/en/pdp/da...t#.Vzi_k5BwUqw
Myself, rather than razor blades, I use a small piece of softwood, applying pressure to break the bond. The wood is harder than the silicone, but likely softer than the tub, so less likely to cause damage. Followed by scrubbing with cleanser.
For sure, new silicone will not stick to old silicone, so you have to get the old stuff FULLY removed.
Windows on Wash likes this.
SPS-1 is offline   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
jlhaslip (05-15-2016)
Old 05-15-2016, 03:48 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,242
I like this option. I have previously use a strong towel to generate the friction. I like the wood option.
I would skip the remover like SPS-1 said. Silicone is just so inert that nothing works well on it and you will be exposing yourself to some nasty stuff.
Best stuff to use here is elbow grease.
Old 05-15-2016, 03:48 PM   #4
JUSTA MEMBER
Rewards Points: 3,574
A wood paint stir stick will remove the bulk of the old silicone.
Then a soft rag and WD-40 will remove any residue, then clean that with a glass cleaner (Windex).
ED
de-nagorg is offline   Reply With Quote
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 37 06-05-2017 05:19 PM
Polyseamseal or GE Silicone II for bathtub caulking ? Rav Plumbing 8 01-16-2013 12:35 PM
Silicone Caulk Removal Cbarnettesq1 Painting 1 11-22-2010 10:31 AM
Silicone Caulk Removal Gary Osterberg General DIY Discussions 2 09-14-2010 01:01 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
