Side By Side Bathroom Remodel - Flooring? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-12-2017, 12:00 PM   #1
Rewards Points: 324
Side by side bathroom remodel - flooring?
I have two 2nd floor bathrooms currently completely gutted. A simple wall separated the two bathrooms, no top or bottom plate - just 2x4 studs.
I've removed the studs b/c I had to replace part of the subfloor, so the two bathrooms is currently one large room.
Does it make sense to get one large piece of vinyl flooring and cover the entire floor and then build a wall on top of the vinyl flooring dividing the room once more into two bathrooms?
Any pros/cons is much appreciated.
Fisher1871 is offline   Reply With Quote
Old 06-12-2017, 07:17 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,692
Re: Side by side bathroom remodel - flooring?
It may be more difficult to lay vinyl through two rooms considering all the pipes, etc. I would go ahead and lay in the bottom plate and top plate so you will have something to attach your studs to and either lay in each room separately with vinyl or ceramic tile (preferred). One disadvantage to building a wall on top is the shrink factor of the vinyl versus the wood that you will have entrapped it with.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 06-13-2017, 10:54 AM   #3
Rewards Points: 324
That is a great point. I didn't consider that laying the floor and then a bottom plate could constrict the expansion/contraction of the vinyl and cause issues.
Thank you!
4.5 ft x 9 ft bathroom remodel = HELP! xcntryskiing Kitchen & Bath Remodeling 8 09-26-2012 01:17 PM
Remodel vs. repair bathroom slab on grade JCTeacher Plumbing 3 04-15-2012 05:54 AM
70's Bathroom remodel Falconag Kitchen & Bath Remodeling 16 01-25-2012 02:40 PM
Help with bathroom remodel!!! jasongilliland Building & Construction 4 11-16-2011 06:05 PM
bathroom remodel in Chesapeake, VA mt dew Building & Construction 2 10-02-2011 07:24 AM
