Shower Walls With No Red Guard - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 01-19-2018, 10:32 PM   #16
Peace be with you
DR P's Avatar
Rewards Points: 1,860
Re: Shower Walls With No Red Guard
Originally Posted by fixit26 View Post
The herringbone has to come out because the preslope wasn't done properly. There is a hump on left side of the drain. Water will pool at the left wall. Also, that's thinset between the tiles and the the drain sits higher than the tile on the right side. It's a disaster.
Previous installer works for a tile company and was doing it on the side. He was def in over his head. I'm assuming he's not a true installer and is just an assistant.
The yellow stuff that is combed was already there. The pan never had problems with leaking but the preslope was off a little in the corners. No water damage behind the walls though.
The first guy chipped up the tile, laid self leveler, put a vapor barrier on the floor only then laid tile on top.
I questioned him at this point about drainage and he said he could freehand it with thinset. (yeah, really...) I should have stopped him there, but I didn't know how bad it really was. After the disaster on the floor I had some real pros look at it and realized I was screwed.
Now here we are
I was afraid of this & why I kept asking about pan...
between that *plumbed* wall & this job,
you've had a real screwy month..
In conclusion, nope; I don't believe you really
need to worry about red guard corners
Peace
DR P is offline   Reply With Quote
shower walls porcelain tile over redguard gregw Kitchen & Bath Remodeling 5 07-31-2015 08:05 PM
gap patch between shower walls morequestion Tiling, ceramics, marble 4 02-06-2013 05:14 PM
Questions on waterproofing tile walls for shower with floor pan. HautingLu Tiling, ceramics, marble 11 09-18-2009 11:12 AM
Rotting shower walls PICTURE Sarah24 Kitchen & Bath Remodeling 6 05-10-2009 12:09 AM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 06:17 PM
