Shower Under 30" Wide? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-27-2015, 10:46 AM   #1
Rewards Points: 396
Shower under 30" wide?
I'm visiting family for thanksgiving and notices the shower we're using is 24" shower width (wall to curb) and about 27 wall to center of curb where the door is. It's 58" wide if that makes a difference.
I'm a bit confused as this is a newly built house so it's not old code. Is the code of 30 inches before the door goes in and to the outside of the curb? Is it once the door goes in from wall to door? Or is it to the start of curb? I thought the shower was actually ok as far as width goes but I just don't understand how it was allowed.
Any idea how it was allowed? I need to put a new one in as part of a basement reno and I'm width constrained so any new flexibility would be much helpful.
Thank you for any insight
MLMIB is offline   Reply With Quote
Old 11-27-2015, 12:33 PM   #2
Rewards Points: 6,901
I don't know where you would find a base or unit smaller than 32x32 and I don't know current code minimums. I also sure would not do it unless I had absolutely no choice.
If I had to look for one that small I would try a mobile home parts supply company or perhaps an RV parts dealer.
That small sounds like the cruise ships where you have an affair with the curtain every time you take a shower.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 11-27-2015, 01:13 PM   #3
Rewards Points: 396
Originally Posted by Colbyt
I don't know where you would find a base or unit smaller than 32x32 and I don't know current code minimums. I also sure would not do it unless I had absolutely no choice. If I had to look for one that small I would try a mobile home parts supply company or perhaps an RV parts dealer. That small sounds like the cruise ships where you have an affair with the curtain every time you take a shower.
It's a glass door and looks quite nice. I imagine their either custom made or cut down the shower pan to fit.
Here's a picture [PHOTO]http://i.imgur.com/FXXVzqL.jpg[/PHOTO]
Old 11-27-2015, 03:07 PM   #4
concretemasonry's Avatar
Rewards Points: 2,716
MLMIB -
I think you are confusing "width" and "depth" of the shower area itself and the size of the opening.
Dick
concretemasonry is offline   Reply With Quote
Old 11-27-2015, 06:00 PM   #5
Rewards Points: 396
Originally Posted by concretemasonry
MLMIB - I think you are confusing "width" and "depth" of the shower area itself and the size of the opening. Dick
Er, perhaps? I didn't measure the door but the shower pan is definitely 24" (23.5 to be exact) from wall to curb, and 58" from wall to wall I the other dimension. I thought the 24 for the width of the shower pan was below code which is triggered the question.
Old 11-27-2015, 07:28 PM   #6
Retired Moderator
Rewards Points: 7,174
As far as I know, there is no size mentioned in any local code that I have worked under---
Old 11-27-2015, 08:26 PM   #7
Rewards Points: 396
This is the code I've always tripped across in my research...
http://publicecodes.cyberregs.com/ic...2_3_sec007.htm
which seems to state 30" minimum in both length and width of shower area.
I've seen it elsewhere stated as.... "Code Requirement: The minimum interior shower size is 30x30 inches or 900 square inches, in which a disc 30 inches in diameter must fit."
I'm presuming the 30 inch disc basically dictates that the 30" minimum in length and width on the shower pan, but this shower and my sisters is throwing me off. I'd really prefer to be able to plan for 28 or so to the curb with 2 inches extra to be gained on the curb as it would make my planning work a lot easier without any heroics.
Old 11-28-2015, 04:45 AM   #8
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,278
I swore that I saw a 30" clearance diameter is in our code up here as well but I cannot locate it now.
Maybe I just Googled the same thing as you.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is online now   Reply With Quote
Old 11-28-2015, 11:16 AM   #9
Tileguy
JazMan's Avatar
Rewards Points: 748
There are specs in the IRC, IBC and UPC codes, but the various states are free to adopt or ignore their recommendations. It's best to check with your local authority.
I always thought the idea was to have 28" of elbow room and have seen to 30x30 or 900 sq. in. spec.
While doing more research I found the California code which in part says the min. finished area is 1024 sq. in. and a 30" circle must fit within the shower space when measured above the threshold. Much more to it, so see your local building department.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
The Following User Says Thank You to JazMan For This Useful Post:
123pugsy (11-28-2015)
Button broke on Shower Head that redirects water to Handheld Massager ace2013 Plumbing 2 01-19-2014 09:18 AM
Shower Rough In - Miscellaneous Questions tev9999 Plumbing 1 02-13-2012 09:40 PM
Piece of junk, leaky shower. How can I improve it? JustinEllard Plumbing 4 10-05-2010 08:45 AM
Failed shower pan in old tiled shower tmpyankee Plumbing 3 07-14-2010 06:43 AM
shock in shower tbwoods Electrical 64 07-23-2009 11:26 AM
