Shower Tub, Floor, Tile, Baseboard Transition Help - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-07-2019, 02:00 PM   #1
Rewards Points: 4
Question
Shower tub, floor, tile, baseboard transition help
Hey all - having trouble figuring out how to tile and trim the edge of my shower.
Using a fiberglass shower pan and will use schulter jolly trim at the edge of my shower tiling. My shower door will be a dreamline semi-frameless mounted to the tile.
I'm unsure what to do at the transition from tile to baseboard to floor to toe molding etc.
I've made a few sketches that I see as options. Want to know if people have a 'best solution' or at least have done this before. Perhaps I'm just over thinking it and need some clarity. I guess the difference in thickness from tile to baseboard is what is tricking me up a bit.
Made some quick sketchup models to show different thoughts.
Code:
Color guide:
Blue - painted wall
Green - tiled wall
White - baseboard
Pink - shower tub
Grey - schluter trim
Brown - floor and toe molding
Option 1: probably the most obvious and simple. My only concern is the closeness of the shower door mount to the edge of the tile.
Option 2: provides more tile overhang, but seems a bit awkward with two quarter-round ends right next to each other
Option 3: Its an option and have seen this before (how the tub in our other bath is done). although i wouldn't say its the most elegant.
Option 4: Use some type of floor transition piece to eliminate the gap between flooring and tub. again a bit awkward with the trim ending early.
not sure if the pictures worked: imgur.com/a/2DNfHbj
As I type this out i'm leaning toward option 1 as it is the definitely the cleanest and I can mount the door a bit towards the inner edge of the lip on the shower tub.
youngt2 is offline   Reply With Quote
Old 05-07-2019, 04:08 PM   #2
retired framer
Rewards Points: 18,526
Re: Shower tub, floor, tile, baseboard transition help
If the floor is tile you don;t have a shoe molding at the shower.
Option 4 with the tile right to the floor at least 4" outside the shower.
Do not use flat bottom gables with scissor trusses.
Old 05-07-2019, 06:13 PM   #3
Rewards Points: 4
What is the significance of the 4" past the shower? I always see showers like this but never understood why.
Old 05-07-2019, 06:31 PM   #4
retired framer
Stopping the wood molding far enough away so it is not constantly getting wet when you clean the glass and same with the painted drywall.
You can find all kinds of videos on how to fix drywall around and close to wet areas. In new houses here they all get at least a 4 or 6 inch tile around above and next to wet areas and seldom see a problem that will ever need fixing.
Old 05-07-2019, 07:27 PM   #5
Rewards Points: 4
Thank you. Makes sense!
Problematic shower oneonesix Plumbing 25 12-28-2014 11:52 AM
Baseboard Transition svaic00 Flooring 10 10-03-2014 08:13 AM
How to join two 1x6s to form a 23' baseboard with a seamless transition? amakarevic Carpentry 12 09-14-2014 10:34 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
