Shower Tiles? - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree7Likes
Old 02-10-2017, 03:35 PM   #16
Rewards Points: 14
Re: Shower tiles?
Originally Posted by 123pugsy View Post
I would create a "dam" from construction adhesive across the tub rim right at the edge of the 2x4's in case your silicone cracks. This would act as a "ledge" of sorts and stop any water from getting past in the event of caulk failure.
If the caulk fails, you'll probably never know it and water will rot out your new wall.
arthall111 is offline   Reply With Quote
Old 02-11-2017, 10:43 AM   #17
Rewards Points: 14
Re: Shower tiles?
What is the average height to run tiles from tub lip up?
Old 02-11-2017, 11:10 AM   #18
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,274
Re: Shower tiles?
Today's fashion is right up to the ceiling.
arthall111 likes this.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 02-14-2017, 12:50 PM   #19
Tileguy
JazMan's Avatar
Rewards Points: 748
Re: Shower tiles?
The 'code', common practice is/was to tile up at least 72" above the floor. Going to the ceiling makes lots of sense, but sometimes looks awkward if there's no soffit above the tub. It's a matter of your taste.
In the old days where most tiles used were 4.25", we went 13 rows up, 55.25" + 2" for the bullnose which totaled about 57.5" +-. the tub is 14-15" and there you go.. roughly 72".
Jaz
123pugsy likes this.
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - MARMO.SIC[email protected]
Old 02-14-2017, 02:39 PM   #20
123pugsy's Avatar
Re: Shower tiles?
Jaz
I didn't drop my ceiling and I have tiles going up to a 9' ceiling.
Have no idea how I will clean them.
It does look a bit odd as you mention.
Old 02-16-2017, 08:01 AM   #21
Rewards Points: 2,472
Re: Shower tiles?
I like L curtain rod. You can even make one with 3/4" copper and the wall flange and it will be strong enough to delete the ceiling hanger. Bend the outside radius and make it 3" outside the tub and the curtains will not stick to you. Flange must have a 2x nailer and use #12 or better stainless screws. There are extra length curtains also so you don't have to use 2.
carpdad is online now   Reply With Quote
Old 02-20-2017, 08:37 PM   #22
Rewards Points: 14
Re: Shower tiles?
I will post more pictures when further along. I am going with a back wall because I want a curved curtain rod. It seem to make shower room so much wider
Sent from my LG-V410 using Tapatalk
Shower tiles fell off, water damaged wall badhaircut Flooring 16 01-24-2013 06:40 PM
Tiles fell off wall in shower Pmmaker Tiling, ceramics, marble 3 02-01-2012 09:09 PM
Mould found under tiles of shelf in the shower. Jacques28 Building & Construction 2 10-04-2010 08:44 AM
Grout peeling out from shower floor tiles. What's the problem? hellstorm Flooring 6 10-21-2009 09:15 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 07:43 PM
