Shower Tiles? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree7Likes
Old 02-05-2017, 01:38 AM   #1
Rewards Points: 14
Shower tiles?
I removed old tiles and behind then is a slab of concrete. Should I remove this and put up backer board or retile over the concrete?
arthall111 is offline   Reply With Quote
Old 02-05-2017, 08:43 AM   #2
Rewards Points: 17,884
Re: Shower tiles?
Post a picture.
What condition is the concrete in now that you have chisled off the old tile?
Old 02-05-2017, 09:00 AM   #3
Rewards Points: 14
Re: Shower tiles?
Old 02-05-2017, 12:45 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 748
Re: Shower tiles?
Looks kinda nasty but how is it structurally? Now would be the time to install a new/tub/ shower valve. Why is the spout still there? How will you interface to the tiles on the left? Are those staying? Why? Is this a quick temporary up date or are you doing more than just the tub surround?
Jaz
joecaption likes this.
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 02-05-2017, 09:26 PM   #5
Rewards Points: 14
Re: Shower tiles?
It's a work in progress. I decided to remove the mortar. Replacing water supply kit. Where the other tiles are is the back of my tub. I would like to build a thin wall on top of tub at back. Can't figure out what to put along cast iron tub rear top to set wonderboard in. Also would need an up right to ceiling at outer edge. I really don't like the L shaped curtain rod and there is a toilet right behind tub so building a regular rear wall wouldn't work.
Old 02-06-2017, 04:24 AM   #6
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,268
Re: Shower tiles?
I wouldn't waste my chance of getting the old tub out if I were you.
A new tub with a wall flange on 3 sides will go a long way to help getting the 3rd wall you desire.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 02-06-2017, 12:01 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 748
Re: Shower tiles?
A new tub is a given isn't it? The tub is old and was not protected during demo. I might consider installing a 54" tub instead of a standard 60". Might work so you can build the wall on the left end of the tub. You need to leave min. 15" from center line of the toilet to the wall.
Jaz
ZTMAN likes this.
Old 02-06-2017, 09:47 PM   #8
Rewards Points: 14
Re: Shower tiles?
What about 2x3 studs notched in half from tub to floor?
Old 02-06-2017, 09:48 PM   #9
Rewards Points: 14
Re: Shower tiles?
Or 2x4 to make it past 45 at corner
Old 02-07-2017, 03:17 AM   #10
Rewards Points: 14
Re: Shower tiles?
I must add I am renting this house,but owner is 85 and a rent to own is being discussed but she wants to keep tub and resurface
Old 02-07-2017, 04:46 AM   #11
123pugsy's Avatar
Re: Shower tiles?
That will work.
Make sure you apply a nice bead of silicone between bottom row of tiles and the tub. Keep the notched part over the tub, off the tub at least 1/4".
I would use PL on the notched part to the outside of tub connection and they will still be as strong as a full stud.
arthall111 likes this.
Old 02-07-2017, 05:42 AM   #12
Rewards Points: 14
Re: Shower tiles?
Originally Posted by 123pugsy View Post
That will work.
What is PL?
Old 02-07-2017, 06:19 AM   #13
123pugsy's Avatar
Re: Shower tiles?
What is PL?
Construction adhesive.
Such as PL Premium.
http://www.lepage.ca/en/lepage-produ...-adhesive.html
Old 02-10-2017, 02:25 PM   #14
Rewards Points: 14
Re: Shower tiles?
That will work.
Thanks for advice. Keeping wood 1/4 inch above tub. Little stuff like that I overlook
Old 02-10-2017, 03:11 PM   #15
123pugsy's Avatar
Re: Shower tiles?
I would create a "dam" from construction adhesive across the tub rim right at the edge of the 2x4's in case your silicone cracks. This would act as a "ledge" of sorts and stop any water from getting past in the event of caulk failure.
If the caulk fails, you'll probably never know it and water will rot out your new wall.
Shower tiles fell off, water damaged wall badhaircut Flooring 16 01-24-2013 06:40 PM
Tiles fell off wall in shower Pmmaker Tiling, ceramics, marble 3 02-01-2012 09:09 PM
Mould found under tiles of shelf in the shower. Jacques28 Building & Construction 2 10-04-2010 08:44 AM
Grout peeling out from shower floor tiles. What's the problem? hellstorm Flooring 6 10-21-2009 09:15 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 07:43 PM
