Shower Tile Surround - Membrane Necessary? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 11:53 PM   #1
I have installed a bathub and plan on tiling the surround with 4" tile and 1/8" grout.
I already have the hardibacker in and I did it without any kind of membrane. I did it this way because the several people I spoke with say it's unecessary.
Now I'm worried I should have done it and am considering taking out the hardibacker to put the membrane in.
Maybe I can get away with skipping the back wall? The problem is I already have the adjacent walls nice, spackled and painted.. It's seriously going to set me back but I'll do it if it's a must.
m1lreese is offline   Reply With Quote
Old 01-08-2012, 04:54 AM   #2
Retired Moderator
Rewards Points: 7,174
If you are concerned add a surface membrane like Red Guard--(Home Depot) -
This is a paint on waterproofing---Very simple to apply and will keep water from penetrating your backer board----
Old 01-08-2012, 10:54 AM   #3
should i not be concerned??
i was reading about this. it seems like the way to go.
the stuff the guy told me to use and that i didn't need anything else is acrylpro. that's what i have right now. would this be ok with redguard?
thanks!
Old 01-08-2012, 11:37 AM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 12
Originally Posted by m1lreese View Post
the stuff the guy told me to use and that i didn't need anything else is acrylpro...
No, take it back. You don't want any premixed buckets in a wet area. You want a modified thinset you mix yourself.
Also, who is "This guy"? Few people who work at the apron stores really know what they are talking about.
Lastly, I'm not that knowledgeable on tiling. What I did before tiling my shower was to get a good up to date book from the library and spend a lot of time here reading.
I would suggest you go to the search function here and look at old threads on the subject. You will find they answer a lot of questions you didn't know you had.
Old 01-08-2012, 12:04 PM   #5
he works in the tile section at home depot. the employees in my area have tiling experience.
Old 01-08-2012, 12:21 PM   #6
Stuck in the 70's
Rewards Points: 12
Even if they do, there is a lot more to building a shower properly than just the tile.
Google "acrylpro review" then decide if you want to follow this guy's advice.
Old 01-08-2012, 12:25 PM   #7
Retired Moderator
I 'acrily pro' is a premixed mastic--take it back--
You want a powdered modified thinset--mastics should not be used in a wet area--they can re emulsify
when wet and also will grow mold behind the tiles----
The RedGuard I mentioned earlier is surface waterproofer--that will keep moisture out of your walls.
Old 01-08-2012, 01:08 PM   #8
ok the acrylpro sounds like crap. i'll be exchanging for redguard and thinset. thanks, guys.
Old 01-08-2012, 02:04 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
m1lreese,
Ackrylpro is not "crap" but it isn't good for this purpose. It has its uses and is a fine product when not mis-used.
If you care to email me privately I would be glad to help you with your project without interference.
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
Tile shower surround above fiberglass shower Gregghea Tiling, ceramics, marble 3 01-28-2011 07:39 AM
Tile Membrane behind kitchen back-splash? ChrisDIY Kitchen & Bath Remodeling 4 04-29-2010 11:08 AM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 10:52 PM
Plastic shower surround on top of tile ok? 1973vw Remodeling 4 04-09-2008 12:22 AM
