Shower Tile Issue - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-19-2012, 03:01 PM   #1
Shower Tile Issue
I am having an issue in my bathroom where gaps appeared on the corners of the wall in the bath, I was told it was caused by shifting foundation since the house is 1 year old. I got a tube of sanded caulk from home depot and used it to fill in the gaps; however, now that it dried the color of the caulk look much darker than on the tube, and the rest of the wall. Is it possible for me to place a white silicone caulk over it? Image of the area is below.
KidGeek is offline   Reply With Quote
Old 05-19-2012, 07:47 PM   #2
Retired Moderator
Rewards Points: 7,174
that corner should have been caulked when the shower was built.
Knife out the bad color caulk--use a razor blade--then recaulk with a better color--
Old 05-21-2012, 06:57 PM   #3
Too Short? Cut it Again!
A new layer of silicone will never stick to what is there. You have to carve it out.
Old 05-22-2012, 09:07 PM   #4
More than a shower tile issue
You have a helluva problem if your tile has shifted vertically by 1/2 inch or more. Mismatched caulk is the least of your worries. Is that corner on an exterior wall, or an interior? If your foundation has "shifted" as you note, you should be seeing other cracks elsewhere in the house -- do you? If you are lucky, the answer is no, and the problem is with your shower install.
jonbt is offline   Reply With Quote
Old 05-22-2012, 09:23 PM   #5
Rewards Points: 17,890
There should be cracks or even gaps at the ceiling if the walls more that much.
Old 05-24-2012, 08:40 AM   #6
We had similar issue with new tile, what a nightmare it was. We gave up and had Bath Solutions replace it with acrylic bath walls that are infused with Microban. Bath was repaired in a day, using it the next, many assortments to pick from, some look like tile. Great product to clean, would recommend over and over again.
http://www.bathsolutions.ca
cyclist65 is offline   Reply With Quote
Old 05-28-2012, 05:38 AM   #7
You can use white silicone caulk over it. It is a good water proofing agent and prevent wall from cracking and crumbling problem. You can also use Shelley product as an alternative of silicone caulk.
______________
home renovations ottawa
alica is offline   Reply With Quote
Old 05-31-2012, 02:37 AM   #8
Thanks for the help guys I found the correct color caulk, btw it's an interior wall that you are looking at and there are some small gaps by the ceiling in that bath that I will also be fixing.
Tile Redi Shower pan question oc250r Kitchen & Bath Remodeling 184 01-18-2019 01:19 PM
Shower pan/ tile problem Pawl Tiling, ceramics, marble 8 01-16-2012 09:32 AM
cheaper alternative to ceramic tile for shower rickd Building & Construction 6 12-08-2011 05:16 AM
Need Shower tile repair advice beerdog General DIY Discussions 7 12-26-2010 10:25 AM
question on tile shower design racebum Tiling, ceramics, marble 19 12-19-2010 02:48 PM
