Shower Tile Floor - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By chandler48
  • 1 Post By chandler48
Old 12-16-2017, 09:23 PM   #1
Rewards Points: 8
shower tile floor
Can I install curb less 4'w 5.5'deep, w lineal drain like this? Cut/slope & add 2 2x4 sisters to each joist 16"on ctr. & cross cripples. Then lay 2, 3/4 treated ply. and Red Coat. then lay cement board,thinset, and tile. 12x23tiles in ctr with hex on the sides. A boardwalk and sand affect. Room is 4 x10 with alcove for toilet and door opposite shower end. Walls are 3/8 treated ply Red stuff and cement board w/ thinset. there will be a 2x12 starter then ply above. 4 wall tiles 10x27 on vert. 1, 8" accent up the ctr. Water is on the long wall near the rear. There will be no glass door or wall. I can make a 3/8 slope. Drain may present a problem. Location of drain is variable. Circle drain will have an issue at the end of slope.
*eddY25722+ is offline   Reply With Quote
Old 12-17-2017, 02:12 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,624
Re: shower tile floor
I'm trying to wrap my mind around your process, but it isn't coming together with the normal method of building a shower pan. Can you post a few pictures of your room and possibly a drawing of what you are planning with links so we can try to come up with a good solution? Treated 3/8 plywood is not a normal wall, either, so we need to clarify that. Not sure what a 2x12 starter with ply above is, either.
Mike Milam and *eddY25722+ like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
*eddY25722+ (12-17-2017)
Old 12-17-2017, 05:22 PM   #3
Rewards Points: 8
chandler- I don't know how to post pic or show a drawing. I want to slope the floor by cutting the joists and then add 2x4's in order to remove and chance of movement. With the shortened distance between joist and 1-1/2" off plywood that should be as ridged as a cement pan? In order to get a 3/8 slope I would have to cut 3" off the one joist. 2xply and 12/8ths for the last joist. That joist would be 4+feet in from the starting edge. If I used only one sheet of ply, I would need to use 2" of cement for a pan? I would have to cut deeper into the joist and use 2x6 or 8 sisters. I am working over a 24" crawlspace.
On the walls at the bottom I was going to use a 2x12 as kick board between studs for strength. I wanted to use the plywood in place of sheet rock. I will red coat that and then cover that with cement board floor to ceiling. I thought the
plywood would be a stronger wall than sheet rock.
The bathroom runs against the outside wall of the house 10'. The room is 4'x10'.
Old 12-17-2017, 07:07 PM   #4
Naildriver
chandler48's Avatar
First off, you don't cut joists in order to make a slope. You build a berm, pack in a preslope of sand mix concrete to satisfy the slope of 1/4" or so from the drain to the edges of the shower. You install 2x12 lumber as backers at the bottom of the shower wall so you will have something to tack your liner to. Then install a pvc shower liner, then your 1/2" cbu for the walls, then your slope on top of the pvc liner, covering the berm as you go. We can provide more information on this, but your method is not going to work. Tell us why you have such a plan and why you want to cut into the joists.
*eddY25722+ likes this.
Larry......
Old 12-17-2017, 09:10 PM   #5
Rewards Points: 8
I want a curb less shower starting the slope down from the existing floor level. I want to use TEC membrane, not a liner.
Old 12-17-2017, 09:24 PM   #6
Rewards Points: 8
chandler48 - I work from my desktop and am NOT good at computer stuff. I just learned how to send a picture in a message from my iphone. I have no idea how to do that or a drawing here. Any direction for me?
Need advice in fixing "contractor's" botched shower floor tile job toocheaptohire Tiling, ceramics, marble 6 04-19-2018 09:09 AM
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 04:10 AM
Tile shower leaking gregsenne Plumbing 9 10-02-2012 09:00 PM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Busting out my shower tile floor and walls. caliskier Building & Construction 3 03-15-2009 08:59 AM
