Shower Side Wall Standard Length - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-13-2012, 01:55 PM   #1
Hello all
I am in the process of framing around my shower pan and am curious if there is a standard distance the side walls should extend past the shower pan. Just to clarify, I have a 34 x 48 shower pan. When I look at the side walls around most showers, they extend past 34 inches… they normally have some tile work that is on the outside of the sliding door that allows you to enter the shower. For the side walls, is there a standard length past the shower pan walls normally extend? I am thinking maybe 3 to 5 inches.
Thanks in advance for your knowledge.
VikingDinKC is offline   Reply With Quote
Old 05-13-2012, 04:16 PM   #2
Rewards Points: 17,890
There is no "standard" I try to use 6" so it's easy to finish the walls.
Old 05-14-2012, 11:47 AM   #3
Excellent, thank you for the feedback.
Old 05-14-2012, 07:47 PM   #4
Retired Moderator
Rewards Points: 7,174
What Joe said.
I shoot for some size that will fit the cap (bullnose) tiles that will be used--Typically 3 inches--or more if the bathroom can stand the loss of more room.
Stud wall return on a preformed shower base latelifebiker General DIY Discussions 5 11-30-2011 03:56 PM
shower wall stability rtoni Building & Construction 7 01-27-2011 04:11 PM
Wall construction for insulation support WillK Building & Construction 3 12-09-2010 01:55 PM
Water seeped through tiles in shower, wall ruined, need help. doogie88 Building & Construction 39 10-07-2008 04:13 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
