Shower Re-caulking - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-05-2015, 11:57 AM   #1
Rewards Points: 50
Shower re-caulking
Hi,
I have a builder grade shower door with two panels that needs to be re-caulked. Originally it was caulked inside and outside everywhere and caulk failed in some bottom corners and along the front of the shower pan from the inside. I have FLORESTONE 4234-1 shower pan and door similar to BASCO THINLINE but poorly designed (no solid corner but strange set of metal profiles inserted one into another). I have few questions.
1. Should I caulk inside where shower door base meets the pan? (red line on pic.1,2,3). What about numerous little gaps where one profile meets another one (yellow lines on pic.1)
2. I found a big silicone blob where threshold meets the wall jamb. Should it be there? (red circle on pic. 2,3)
3. Should I caulk around the escutcheon?
4. Should I push the caulk deep into the gap between tiles and shower pan? I'm afraid to fill up the water escape channel along the lip that should direct any water that penetrates grout to the side recess in the pan.
Sorry for being too wordy and unclear. Thanks.
barmaley is offline   Reply With Quote
What type of caulking do I need for shower ? Diydude905 Drywall & Plaster 10 09-27-2012 04:29 PM
Shower pan/ tile problem Pawl Tiling, ceramics, marble 8 01-16-2012 09:32 AM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
caulking shower stall questions, removal, grout sealing etc detyianni Plumbing 0 11-29-2010 09:00 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
