Shower Pre-slope Mortar - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-20-2016, 05:39 PM   #1
Rewards Points: 2
I have put in a pre-slope mortar bed for a shower pan using the Pre-Pitch system and 4 to 1 Mortar bed mix. Before I install the liner there are a couple of places that aren't sloping to the drain almost level. What can I do to fix the problem? Can I mix up a little more mortar adjust the slope? I don't want to go further until it's right.
time42play is offline   Reply With Quote
Old 03-20-2016, 05:53 PM   #2
Retired Moderator
Rewards Points: 7,174
Re: Shower Pre-slope Mortar
Yes--touch up the low spots right over the existing---a slightly damper mix might be needed.
Jim F (03-23-2016)
Old 03-23-2016, 04:14 PM   #3
Rewards Points: 462
Time42play is that the Goof Proof system you are talking about? If so, how do you like it? Do you have any pictures to share?
Jim F is offline   Reply With Quote
Old 04-11-2016, 10:23 PM   #4
Jello Wrangler
Rewards Points: 539
Use a Kerdi pan and skip all the hassle and steps.
ChiTownPro is offline   Reply With Quote
Tags
mortar bed , shower base , sloped concrete
mortar under my shower pan... Ed911 Plumbing 9 11-07-2012 07:46 AM
Shower pan mortar califmonster Building & Construction 6 07-30-2011 06:20 PM
Hardiebacker and shower pan mortar bed 04snr Kitchen & Bath Remodeling 1 01-26-2011 09:39 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
Mortar to use in floating a shower pan? kemerick Flooring 2 11-12-2007 01:35 AM
