Shower Pan Question - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-08-2014, 10:22 PM   #1
Rewards Points: 16
Shower Pan Question
I am looking at putting in a shower in a basement and had a question about putting in the shower pan. I am planning on having a linear slope to a trench drain, which I assume works the same except for the top piece.
I am familiar with making a shower pan with mortar and membrane, but today I came across a method that used a different waterproofing system. It seemed a lot simpler, and I was wondering if it is a viable option or if I should go the membrane route.
If anyone has negative experience with trench drains let me know. The plan was a doorless large shower, and I think a linear drainage system would work better and that made me think trench v. traditional drainage.
carter72 is offline   Reply With Quote
Old 07-08-2014, 10:25 PM   #2
Rewards Points: 16
Just realized I didn't post what I was talking about...
http://www.mrmoneymustache.com/2012/...-shower-cheap/
Old 07-09-2014, 05:40 AM   #3
Retired Moderator
Rewards Points: 7,174
Look up Latacrete--Hydroban---I do not trust Red Guard for a shower pan--might work but I trust the thicker Hydroban---the sealing of the Hydroban to your drain is the key to success---that link misses that detail--
Old 07-09-2014, 07:32 AM   #4
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
What brand trench drain are you planning on using?
I'm putting Kerdi membrane under my floor, one straight slope to the trench, no muss no fuss.
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 07-09-2014, 08:03 AM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 12
No personal experience, but there was a thread floating around here recently that mentioned when choosing one, you want to make sure you can remove the grate for easy cleaning and maintenance.
Shower remodel question farmery Remodeling 5 03-23-2013 11:27 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 08:11 PM
Prep Shower Walls / Shower Bench Question LeviDIY Remodeling 8 06-10-2011 05:09 AM
Custom Shower Plumbing Question PhilStubbs Plumbing 0 04-24-2011 09:39 PM
AAV Shower Question PADIY Plumbing 8 01-20-2009 04:49 PM
