Shower Pan Pre Slope - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-24-2015, 08:55 AM
Rewards Points: 4
Shower pan pre slope
Hello! I put in a shower pre slope using goof proof and the sand I mixed it with ended up being way coarser than what I saw in YouTube videos. I'm sure there is a general slope down to the drain, but there appear to be some spots lower than others. Is this a big deal for the pre slope? I bought the correct sand for the slope on top of the pvc vinyl barrier. It was a lot harder to smooth the coarse sand , and I'm terrified it will not be acceptable. Please, any guidance regarding whether I can continue is appreciated!
Jacob
Jakeaba is offline
Old 10-24-2015, 07:40 PM
Tileguy
JazMan's Avatar
Rewards Points: 748
Hi Jacob,
How could anything go wrong......it's goof proof, if thought.
Hopefully you used more than just sand. You can buy the right mix already blend. What did you use?
Is the drain the lowest spot, how far from the center of the drain to the furthest corner? Using a level or straight edge and level, what is the height difference?
You seem to not be sure if there's a continuos slope to the drain. Please check it again, should be kinda simple. Yes it matters. The shower pan will follow the pre-slope contour.
Different areas of the country sometimes have different types of sand. All should work, but I would say coarse should be easier than fine.
If the overall floor has the correct slope, you should be able to fill in the low spots to make it continuos and meet min. " per foot from the corners.
Post a few pics.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
JazMan is offline
Old 10-26-2015, 11:47 AM
Rewards Points: 4
Pictures
Thanks for the reply......here are some photos I took, hopefully you can see what i mean....I used a 4:1 "sand" to portland cement ratio. There is a somewhat continous downslope, but its not smooth like a slide or anything.....am I being to picky? Id just like to be sure its going to be ok before I cover it up forever
Shower pan pre slope-img_5195.jpg   Shower pan pre slope-img_5187.jpg   Shower pan pre slope-img_5185.jpg
Jakeaba is offline
Old 10-28-2015, 01:53 PM
Tileguy
JazMan's Avatar
Rewards Points: 748
Maybe you haven't had time to answer my questions, I've got time, no problem.
4:1 is perfect for shower deck mud, as you already know. But how it's placed is more important the the exact blend ratio.
Then the pan will somewhat drain excess shower water to the drain's weep holes, (if you don't plug them in the next step). We have no idea if you're being too picky.
" per ft. continuous is the min slope you should have for everything to work right. You can fill slight dips and at the same time make the surface smoother and stronger with thinset.
Make sure to install supports between those studs before the next step. Ever do a shower pan before? How are you going to build the curb and fold the membrane? How you gonna install the concrete backer? Got a plan?
Jaz
JazMan is offline
Old 02-29-2016, 01:53 PM
Rewards Points: 462
Old thread I know. It looks like the OP abandoned it. I'm thinking he need to use more quick pitches in between. Their instructions recommend no more that 2 feet apart to make the screeding easier. I still don't know if I'd use this system or not.
Jim F is offline
Shower Leak Herk_Man Plumbing 10 04-14-2013 04:19 PM
Repairing Botched Shower Tile Step kyann38 Flooring 10 10-23-2012 05:34 PM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
