Shower Pan Mud - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Jack E
Old 11-11-2017, 07:05 PM   #1
Rewards Points: 193
Shower pan mud
I'm getting ready to lay the pan slope layer of mortar in my shower. I'm still a bit confused on which brand/type of mortar mix to use. My local HD had Quikrete Mortar Mix so I bought four bags. They didn't have any "sand and topping mix" or other types I have read about. Can I use just the Mortar Mix by itself or should I add sand to the Mix? Thanks
Jack E is offline   Reply With Quote
Old 11-12-2017, 05:07 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,626
Re: Shower pan mud
You'll have to mix 5 parts sand to the mix. Some folks make different combinations, but 5:1 should give you a good one.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 11-12-2017, 07:33 AM   #3
Rewards Points: 193
Re: Shower pan mud
The Mortar Mix I bought is made of "uniformly blended mixture of fine sand and Type N masonry cement." Given it already has sand mixed in should I still add 5 parts sand to 1 part of the mix? Or should I return and buy pure Portland Cement and mix 5:1. Sorry if I'm making this more complicated than needed but I find the mud terminology and purchase options a bit confusing - I want to make sure I get it right. Thanks
Old 11-12-2017, 07:43 AM   #4
Rewards Points: 898
Re: Shower pan mud
Maybe a different home depot in your area will have it. Check their website.
https://www.homedepot.com/p/Quikrete...0360/100318505
Instructions:
http://floorelf.com/how-to-make-deck-mud
BIG Johnson is offline   Reply With Quote
Old 11-12-2017, 07:56 AM   #5
Rewards Points: 898
Re: Shower pan mud
You can do that but PC comes in 94 lb sacks. You’d need a scale to weigh out half the bag then add 4 60# sacks of sand.
Type N mortar has lime. Not sure what that would screw up. It must be something or that’s what everyone would use.
Old 11-12-2017, 12:02 PM   #6
Rewards Points: 193
Re: Shower pan mud
Thanks for the links and advice. I'll return the Motar Mix and pick up some "sand and topping" mix and add additional sand. It looks like other HDs in the area carry it.
chandler48 likes this.
Tiling pre-existing cement shower floor pan? KerryOn Kitchen & Bath Remodeling 3 07-14-2015 05:38 AM
General Questions w/ Pics on 1st Time Shower Pan Build/Install amodoko Plumbing 10 06-10-2015 02:45 PM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
