Shower Pan For Large Tub Size Area - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By Nealtw
  • 1 Post By 195795
  • 2 Post By chandler48
  • 1 Post By jeffnc
Old 12-30-2018, 08:56 AM   #1
Rewards Points: 6
Shower pan for large tub size area
We are tearing out our prefab tub/shower. It's one of those 6'x3' prefab fiberglass that was original to the house from 1999.
We are going to replace it with a tiled shower area the same size.
I'm looking at different options for the shower pan. I've thought about pouring cement and waterproofing with RedGard but I think it's too large of an area and would be a lot of concrete.
What are some other options? I've looked at Wedi and I think they can make custom sizes.
wesmon is offline   Reply With Quote
Old 12-30-2018, 04:25 PM   #2
Rewards Points: 1,272
Re: Shower pan for large tub size area
Originally Posted by wesmon View Post
We are tearing out our prefab tub/shower. It's one of those 6'x3' prefab fiberglass that was original to the house from 1999. We are going to replace it with a tiled shower area the same size.
Thank God - one less in the world - we're making progress !
Do yourself a favor and put in a mud pan so it's right the first time.
And you might want to consider a pebble floor - slip resistant and nice on the old dogs in the morning
195795 is offline   Reply With Quote
Old 12-30-2018, 07:10 PM   #3
Rewards Points: 2,452
You may find standard pans by using some of the footage for wider curb and sitting. 2x6 curb example. Costs add up, example, enclosure if wanted. So you may want to shop for these things first and may decide to close up some of that space.
carpdad is offline   Reply With Quote
Old 12-31-2018, 05:44 AM   #4
Naildriver
chandler48's Avatar
Rewards Points: 3,604
To clarify, you don't "pour" a shower pan. It is packed in as a pre slope, then membrane added, then a final slope. The "mud" is only slightly moist so it can be packed in. Here's a link. https://floorelf.com/how-to-create-a...r-floor-part-1
Remember, too, your new drain must be 2" in diameter whereas your tub was probably only 1 1/2".
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 12-31-2018, 07:09 AM   #5
retired framer
Rewards Points: 18,482
No matter how the base is made or installed we always add blocking around the bottom.
chandler48 likes this.
Nealtw is offline   Reply With Quote
Old 12-31-2018, 11:17 AM   #6
Absolutely - that's what the rubber membrane gets fastened to
Nealtw likes this.
Old 12-31-2018, 03:48 PM   #7
Naildriver
chandler48's Avatar
I always band it with 2x12's at the 36" mark as well (centered). Someone will want a handicap rail put in, so may as well do it during construction.
firehawkmph and 195795 like this.
Larry......
Old 12-31-2018, 03:54 PM   #8
Outstanding idea !
Old 12-31-2018, 04:20 PM   #9
Rewards Points: 5,690
Kerdi shower pan.
firehawkmph likes this.
jeffnc is online now   Reply With Quote
Old 01-24-2019, 01:53 AM   #10
Rewards Points: 484
Best to float the concrete for drainage and then apply a membrane that is designed for the drain you plan to use. I like the linear drains along the side wall of a shower and you can get drain covers to which tile can be attached using the same tiles as you use for the rest of the shower. This is a good time to put in a curbless shower.
Kerdi products work very well but you may find it difficult to locate people with experience installing them and so most will try to convince you to do it the way they have been doing it for the past 25 years.
Be sure that the plumber puts in balanced mixing valves so when someone flushes a toilet someone in the shower does not suddenly get burning hot water.
Calson is offline   Reply With Quote
Shower Help jessicalouise5 General DIY Discussions 4 04-09-2013 10:14 AM
Tile over stucco in shower area c2g Tiling, ceramics, marble 0 01-24-2013 10:12 AM
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 07:07 PM
creating new shower floor/ slope??? Bob Funk Plumbing 2 03-01-2010 04:22 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
